Ive noticed a lot of posts about stalling bonneville that seem to go unresolved
I will be doing a write up that deals with my particular issues and will see it through from now until the issue is resolved in hopes that when someone else may run into this same problem they will be able to reference this thread. Now for my problem.
Car is a 1994 Bonneville N/A
Bonnie has 129,7xx miles
It recently started acting kinda funky.
As you apply throttle and the rpms build the car seems to hit a rev limiter almost like fuel or ignition is being cut. If you continue to apply throttle eventually the car revs past the "rev limiter" and then shuts off. It will start right back up no problem and will idle fine.
Sometimes this happens at about 3k rpm or 3500rpm other times its as low as 1800-2000rpm.
The car seems to lose electrical power as the voltmeter drops before eventually dying.
A little more info on what has been checked out already:
Battery-Test Passed
Alternator- Test Passed
Ignition Control Module- Test Passed
All 6 Coils have spark
All 6 injectors are receiving signal
No vacuum leaks
No CEL or codes
I cleaned the MAF just after this started happening and it did nothing.
Gas MPG dropped from about 20-21 to 17
Humid days seem to make the problem worse (could just be a coincidence).
I know about the ground bus under the drivers carpet. Its corrosion free and has good contact. lol
I will be checking the fuel pressure just as soon as I can locate my tester.
Ive read that the fuel pump relay can go bad on these cars Im going to test this out but I doubt it is the cause of my problem.
I will be checking/testing the crank sensor as well but I doubt this is the cause of my problem.
TPS will also be checked since it has given me problems in the past but again I doubt this is the cause of my problems.
I am thinking that this could be a MAF issue or even the ECM since things can get real wonky.
Here are some videos to what it does.
This was taken earlier today in park: http://youtu.be/9oFn8tARzu0
This one was taken while driving Saturday afternoon: http://youtu.be/ClJY86ccr-s
If you guys have any suggestions please speak up. In the mean time I will go back to digging around this site.
p.s. sorry for any grammar mistakes. I didn't proofread before posting. Im tired.
