Stability system and abs
Rubidon
- Year and Trim: 2000 SSEI
Where are the stability system faults stored? I have had this car for about 8 months and I get the service stability light and tire pressure light. I usually just reset them so they don't blink until I can get the problems fixed. Recently I have been driving and the chimes will go off but nothing across the DIC, and the usual faults seam to have e delay for some reason. So I hooked up an actron code reader to it and when I tried to read the abs codes it aid link fault? I tried multiple times
GXP front break upgrade, hockey puck front mount, aeroforce gauge in right top vent, Intense FWI
Re: Stability system and abs
you need a ABS code reader.. you can get an app for your phone and a bluetooth OBDII adapter or you can get a ABS Code reader..
http://www.amazon.com/s/ref=nb_sb_ss_i_ ... bs+scanner
Shane "RedZMonte"
2004 Z16 Z06: Virgin
Rubidon
The code reader did abs. I have used it many times to pull them up but this time it kept saying link fault and the usual tire pressure and check stability system warnings weren't coming up on the DIC. One more thing I noticed when it chimes randomly while going down the road the steering gets noticeably firmer.
- Archon
It sounds as if you have a problem with the EBCM.
Hope you don't have to buy a code reader just for this. Advance Auto pulled up codes with descriptions for my ABS system including tire pressure.
As I understand it, the tire pressure code will engage if it measures a significant enough difference in pressure (not necessarily low pressure) so just make sure all of your tires are at the same PSI. If that stops the tire pressure warning (you'll have to clear it one last time) maybe that will narrow your search.
2000 Dark Bronzemist Pontiac Bonneville SE 3800 Series II L36
1998 Bright Arctic White Chevrolet Lumina LS 3100 Generation III L82
Rubidon
Thanks I didn't know advanced would do that with abs,the tire thing is because the previous owner put aftermarket rims on it and didn't put new sensors in.
- crash93ssei
- Retired Moderator
- Year and Trim: 2002 SE
There are no sensors for the tire pressure system. The system reads the individual wheel speed sensors and based on that it will say low pressure. A low tire will spin at a slightly different speed then a fully inflated tire so that is how the system works. Once the tires are aired up the light will stay on until it is reset. Without the DIC just hold the tire pressure reset button until it resets, with DIC scroll through until it goes to the tire pressure screen then hold reset for about 5 seconds or so until it resets.
Rubidon
Ok thanks crash
Rubidon
I finally got the code reader to link so i could pull some codes:
c1214
c1245
c1248
c1254
c1255
c1277
c1287
c1288
c1298
holy poop!! I think i will start with the EBCM like Archon suggested.
c1214
c1245
c1248
c1254
c1255
c1277
c1287
c1288
c1298
- haro1225
- Posts like a Northstar
- Year and Trim: 2004 GTO
If you can't find one for some reason this place can fix it.
http://cheap-abs.com/vrpontiac.html
-Ryan
2013 Audi Allroad Quattro
yourgrandma wrote:Hi.
Rubidon
Doesn't look good called three recycle yards and no good. Looked on car-parts , no good called a few places on there no good.
So if any one has one laying around hit me up!!
- Archon
Have you contacted Harofreak00?
Rubidon
Yes I did, he doesn't have one laying around.
- Archon
Then you may want to consider a rebuilder as haro1225 suggested, if you can be without the car for a few days. They often have fairly quick turn-around with reasonable prices.
