2003 SSEi ABS Code
redwingsfan34
Year and Trim: 01 Buick LeSabre
2003 SSEi ABS Code
Post by redwingsfan34 »
On a 2003 SSEi, I get Intermittent ABS, Brake, and Trac Off lights, with "Service Stability System on the DIC. It will come on and off randomly as I'm driving. Had the codes read - came up with C1298: PCM Class 2 Serial Data Link Malfunction.
At first I thought it was going to be the ABS Module. But now I'm not so sure.
Anybody ever have any experience with that code?
- Robb -
Supercharged 2001 Buick LeSabre
1992 Pontiac Bonneville SE | Pics | Long Gone
Archon
Re: 2003 SSEi ABS Code
Post by Archon »
It still could be. This is some of the information regarding that code:
Possible causes of this DTC are the following conditions:
The EBCM has a class 2 serial data transmit fault.
The PCM has a class 2 serial data receiver fault.
The class 2 serial data line has an extremely high amount of traffic.
Loose or corroded EBCM ground or PCM ground.
