Are GXP calipers a direct swap?
MurderMitten
Year and Trim: 2006 Saab 9-3 SportCombi
Post by MurderMitten »
If I get some GXP calipers for my SLE, what do I need to do to put them on? Are the line fittings the same? Do they bolt on the same and do I need bigger rotors?
-Mike
-17x8 OZ Racing Superleggera wheels- -GReddy Exhaust- -K&N Panel filter- Tinted Windows- -Blacked out side markers-
Tune coming soon
2000 Bonneville SLE - Totalled
Re: Are GXP calipers a direct swap?
Yes, you need the proper rotors. Usually the calipers come with the brake lines (little different), although old rubber brake hoses aren't always the smartest thing to reuse. They bolt on the same, but you also need the special bolts that the GXP calipers use.
MurderMitten
If I take the calipers off a junkyard GXP I have the bolts only.thing is that whoever pulled the engine just cut the brake lines instead of just undoing the lines so id need new lines
-Mike
Tune coming soon
Parts store should be able to get you new lines. That's not a biggie.
crash93ssei
Post by crash93ssei »
For GXP front brake swap you need calipers, caliper slide bolts, brackets, bracket bolts, and the flex brake lines. All of these are must have items, without them it won't work as they are specific to that setup.
jnl518ssei
Year and Trim: 2000 ssei
Post by jnl518ssei »
Not trying to highjack the thread,but what about the rears?
crash93ssei
Rears you need the brackets and maybe the bolts, but the calipers are the same.
optimist prime
Year and Trim: 00 sle n/a
2002 camaro project
Post by optimist prime »
Looks like ill be doing a j/y run for mine also
Upload from http://www.pontiacbonnevilleclub.com/ga ... p?pid=2252
2002 camaro 3800 v6 red headman headers ,Fwi,cat back exhaust currently has engine misfire
