So I drove the 88 some distance for the first time and I noticed right when it changes from 1st to 2nd gear I get a rattling noise and a vibration from the passenger side. I assume this is the Harmonic Balancer telling me its getting a bit long in the tooth? I understand that this is a common issue.
At first I thought it was a CV but it does it going straight and during turns, and always around 2k-2500 RPM. If I drive more like an a$$hat It doesn't make the noise at all. It goes all the way up to 60 with no vibrations or noises.
The car drives absolutely beautiful other than that, so I do hope it not Transmission/Differential related.
1998 Oldsmobile 88 LS w/ FE1 Float Suspension, Leather and Power Everything - Totaled (Rolled!) out during Winter of 2015 by Sister Click HERE for project thread.
2002.5 Blazer - Stock Stuffing 30s, SLP ZR1 Replicas, Dynomax Catback, TONS of other mods. Click HERE for project thread. - DD
The harmonic balancer usually presents itself at idle. Is it possible to grab a vid?
Also remember the torque axis mount is in that neighborhood too, and can show problems with age, or if its not bolted together and correctly
~Randall~
Not right now but I can. Like I said it always presents itself around 2k when it shifts from 1st to 2nd. Never any other time. I was thinking it could be a motor mount too....The thing is quiet when in park and revved and at idle.
Is the axis mount that mount that I had to take apart when I replaced the serpentine belt?
I was thinking that was a *dang* good possibility myself. It looks loose.
Hah, well that can't be helping at all. May be a good idea to check the other two mounts. That one is normally the last to go.
~Randall~
I'm dealing with same issue right now. Weird enough I just started doing some research on it today. I'm thinking it could be that shock absorber mount.
