stumble and blinking ses.
irish91983
1992 Bonneville SSEi (Sold)
Post by irish91983 »
Just a little while ago my car started to stumble and the ses light stared to flash. It only stumbles when I get on it. Im thinking plugs or wires. Any ideas?
Thanks, Keith
2001 SSEi Bumbles
Angel Eyes ~ Cleared Corners ~ Tinted Tails ~ Intense FWI ~ 20% Tint ~ 180 Drilled T-Stat ~ GXP Brake & Suspension Upgrade ~ Alternator Rewire ~ Intense Shift Kit ~ Headers ~ Tr 6's
Fan over ride~NGK Tr 55's~180 Drilled t-stat~Clear Corners~Angel Eyes~Tinted Tails~Magnaflow Cat
crash93ssei
Re: stumble and blinking ses.
Post by crash93ssei »
Flashing SES is usually (or always?) P0300 random multiple cylinder missfire. I would definitely do plugs and wires first and see if that cures it.
bobgto65
2004 Bonneville GXP
Post by bobgto65 »
and if that doesn't work, it is likely a bad coil.
bobgto65
Franksdad
Year and Trim: 2001 SLE
Post by Franksdad »
Happened to me was a misfire, was a bad plug.
2001 SLE tints | Series III L26 | 180 T-stat |
2002 Monte carlo SS Dale Earnhardt edition (waiting on salvage title)
Go through your ignition system.
I agree, check and replace the plugs, check and/or replace the wires, then if it's still there, time to check the coils and ICM. The flashing SES indicates a potentially catalyst damaging condition, which is usually some sort of misfire. Keep the plugs in order when you take them out, note if one is darker or lighter than the others. Light would indicate a lean condition, pitch black would mean very rich, that that plug isn't firing. Do you have access to a scanner to see which cylinder is misfiring?
irish91983
All 3 Coils And Icm Are Brand New. OnlyA Few Months Old. Plugs And wires Are About Due.
2001 SSEi Bumbles
What brand are they?
irish91983
I Believe They're BWD.
2001 SSEi Bumbles
Franksdad
Post by Franksdad »
Dude you should definitely run a code reader to identify the misfiring cylinder, then swap the plug on that cylinder and see if it fixes the problem, it did it for me.
irish91983
Tested Coils Replaced Plugs And Wires. Still Have A stumble. Sprayed All Vacuum Lines And Intake No Leaks. If I DriveEasy It's Fine. When I Need Power It Stumbles. Could It Be A BoostProblem?
2001 SSEi Bumbles
Post by gonzo4191 »
how did you test the coils? a misfire can also be fuel related. are the wires routed properly
irish91983
First Thing I Checked And Rechecked And Checked Again Was The Firing Order. Used The Techinfo Guide ForThe Coils.
2001 SSEi Bumbles
irish91983
When I scanned it I got a code p0300 misfire detected. Also had 2 stored codes for my map seneor and one for the tps.
2001 SSEi Bumbles
rfoster
Year and Trim: 02 SSEi: :(
02 Elantra GT: getting me by
Post by rfoster »
Test your TPS.... when mine was going bad, it stumbled, even at idle. But, regardless, all codes need to be addressed. If it is a MAF issue, don't buy a new one, just grab a used one from Haro. Less headaches. What brand of plugs, wires, and coils did you use?
macksdaddy77
Year and Trim: 2002 bonneville ssei
124k
Stock for now
Post by macksdaddy77 »
i actually have this right now on my 02.. scanned it with torwue pro and found cylinder 5 misfire.. like everyone said check ur plugs and wires..
irish91983
Plugs and wires are brand new only 2 days old. Coils tested good. Icm and coils are only couple months old. Cleared the codes last night just scanned it now only getting a P0300 code. What else should I do? Also I don't have a cat and tps tested good also
2001 SSEi Bumbles
macksdaddy77
124k
Stock for now
injectors maybe.
crash93ssei
It doesn't matter if if the parts are right off the production line, they can be bad right then or only last for ten minutes, I have seen several plugs bad either right out of the box or within a couple days fail.
Is it misfiring at idle as well or only when under a load?
If you are very careful you can pull the wires off the coils one by one with the engine running and you will easily see and hear the spark jumping down the coil towers, that will verify that at least the coils are firing at idle.
irish91983
After retestingEverything And All Passed I Figured What The Hell Still Have My Old Coils Sitting And SwaP Them In And Hope For The Best. Yup It Fixed It Had A Bad Coil Even Thou They Tested In Range.
2001 SSEi Bumbles
