need part names/numbers please
Night Crawler
Year and Trim: 2002 Bonneville SE
Post by Night Crawler »
I need the name and number for the wiper control modual that is attached to the driver side wiper arm. I believe this my be my problem for my wiper pump not working. (already replaced the pump) I read that water can get into it over time and wreck the circuit board.
Also need to know the name and number for a suspension part, hard to explain but it's in the rear end, just in front of the rear tires. I think it's the sub frame bushings but not sure. If anyone has a pic of the underside of our cars, i can show you exactly where i'm talking about.
Thanks in advance
FWI, converted low beam bulbs into high beam bulbs, 20% tint all around, MSD wires, NDK TR55 plugs, auxiliary line in, scan gauge, custom FloPro/MagnaFlow Cat back exhaust
2002 Bonneville SE
MrJiggy716
Re: need part names/numbers please
Post by MrJiggy716 »
can you explain your wiper problem a bit better it sounds like your squirts aren't working?
-Justin
Night Crawler
2002 Bonneville SE
MrJiggy716
Oh OK... I had the same problem http://www.pontiacbonnevilleclub.com/fo ... lit=squirt
I think your problem is in the switch in the actual stalk as was mine. If it was the circuit board, its likely your wipers wouldn't work as well. Pull one out of the bone yard or rock auto has them for pretty cheap (much cheaper then a new wiper motor set up) its an easy install pretty much plug and play maybe a half hour at most. Id definitely try that first ....
-Justin
Night Crawler
Can't find it on rock auto
2002 Bonneville SE
I have good used ones for $30 + shipping.
MrJiggy716
Id go with Andrew, Rock is charging 120+ for new ones, thought they were cheaper last I checked...
-Justin
Night Crawler
anyone got the undercarriage pic of a bonneville so I can pin point the other part i'm looking for?
2002 Bonneville SE
Night Crawler
this part i need is causing a flat metal bar to crush my emergency brake line.
2002 Bonneville SE
Night Crawler
well installed the new wiper arm and it WORKED YAY!!!!!!!!!!! Thanks haro.
And i found the other two parts I need. They are called inulator: rear axle control arm support. #49 (canada version all the numbers are different so ours is 45, pic is american)
2002 Bonneville SE
I'd just call that a subframe bushing. I should have one.
Night Crawler
i need two. both of mine are shot and are crushing my emergency brake cable. as above it is part 49. I ordered some today but when I went to pick them up, the ones they had were part 45 on that diagram which are smaller.
2002 Bonneville SE
