What am I doing??
- J Wikoff
- Year and Trim: 1992 SSE
Re: What am I doing??
Love that silver!
- SSEiMan01
03 PAU - Location: DeKalb, IL
Beautiful! Can't wait to see some cleaned up pics.
James May wrote:Hello.
- 2000Silverbullet
- Retired Gearhead
Slept like a baby last night. Made it home late last night. The three hour Ferry ride was a bore. TG for LTE.
YA WOW JOHN there are pine needles everywhere. I can't tell what colour the interior is.
You are definitely a truck person!
This is gonna take some time.....
Rode like the dream I remembered. Smoooth!!
I hope I can hold back and not overspend.
On the down side the TC light is on and the Low Coolant light and the passenger side molding is falling off.
On the good side the gauges all work.
....and did I say how much frogging needles are plugging the air vents...
If it wasn't freezing outside is be cleaning now....
- 99BonnevilleSE
- Posts like an L27
- Year and Trim: 1996 SSEi
Excuse me while I wipe the gallons of drool off my laptop....
I'm backkkkkkkkkkkkkkkkk!
- JMH1950
- Posts like an L36
- Year and Trim: no longer a Bonneville owner
You must be a city boy,Paul. There isn't a pine tree anywhere near here. Those are fir and hemlock needles. Let anything sit in my driveway for more than an hour and it will be covered with them. Look on the bright side, it will keep you out of trouble for a long time picking them all out of there.YA WOW JOHN there are pine needles everywhere. I can't tell what colour the interior is.
2001 F150 a basic six cyl with 5 speed manual trans.wjcollier07 wrote:Darn it John...now you got me thinking mine's not big enough.
'66 Piper Cherokee 360 CID , 180 hp, 155 mph @ 2500 rpm, drop in K&N filter.
- 2000Silverbullet
- Retired Gearhead
Just got back from a short ride and see what you mean now John about the power wall. Anything above half throttle and it surges like you're on and off the throttle but no acceleration......
- J Wikoff
Plugged cat?
- 2000Silverbullet
- Retired Gearhead
no cat
- RJolly87
Dirty MAF? Airbox full if assorted foliage?
~Randall~
- 2000Silverbullet
- Retired Gearhead
Previous owner tried all the obvious fixes...cleaned the inlet and MAF several times.....the intake manifold and supercharger were rebuilt 4 years ago. Replaced computer and coils. No codes. No CES light. Fuel level at 7/8th full.
Suspect fuel pump....
- JMH1950
- Posts like an L36
Paul, one more possibility. For almost a year now there has been a problem with something in the gas plugging service station fuel filters. I'm wondering if some of that crap has gotten past the gas station filters and has partially plugged the sock on the end of the fuel pump. Fuel filter was changed without any difference noted.
I started having this problem a few months after the gas stations started having plugged filters every 7 -12 days.
- nos4blood70
Can't wait to see more pics!
- 2000Silverbullet
- Retired Gearhead
There was no "Silver" colour listed for 94....this is a light grey metallic. I'm calling her the Goose...the Grey Goose. My favourite vodka too.
http://i22.photobucket.com/albums/b307/ ... 8b8c4b.jpg
http://i22.photobucket.com/albums/b307/ ... 1391973816
http://i22.photobucket.com/albums/b307/ ... 629a0c.jpg
http://i22.photobucket.com/albums/b307/ ... e5568c.jpg
http://i22.photobucket.com/albums/b307/ ... 74fcc2.jpg
http://i22.photobucket.com/albums/b307/ ... 4a1945.jpg
- 2000Silverbullet
- Retired Gearhead
Only way to rule it out is change the fuel pump and sock.....as soon as the fuel level gets down to 1/4 or less.....aul, one more possibility. For almost a year now there has been a problem with something in the gas plugging service station fuel filters. I'm wondering if some of that crap has gotten past the gas station filters and has partially plugged the sock on the end of the fuel pump. Fuel filter was changed without any difference noted.
.....unless someone else has experienced the motor boating effect and knows what causes it....
- SSEiMan01
Grey goose. I like it. The car and the vodka.
Is the TPS in good working order? And does the fuel pressure drop off when the surging happens?
- 2000Silverbullet
- Retired Gearhead
TPS unknown. Good fuel pressure at idle and surging doesn't happen if fuel tank full.
What should resistance values be?
- J Wikoff
Sounds like the pump gets weak when it gets warm. Less fuel = warmer pump. Mine did that before I finally replaced it.
- 2000Silverbullet
- Retired Gearhead
Lots of options for a fuel pump. Any recommendations?
Oh and now that I look closer....the sunroof leaks and has destroyed the head liner and soaked the rear rug...
...the old grey goose needs some TLC....
Delphi or Delco for the fuel pump are always good options. Expensive tho...
