Brakes dragging
00bonne
Year and Trim: 2000 ssei
Brakes dragging
Post by 00bonne »
just put new brake pads on the front and the passenger side is dragging
Re: Brakes dragging
Then you get to put new calipers on too.
redzmonte
Year and Trim: 2000 SSEI
Re: Brakes dragging
Post by redzmonte »
how did the slide pins look? did you lube the slide pins? mine had crust and rust on one of the brake pins.. Wire brushed them clean and lubed very well and freed it up. if the sliders are good then you might need to replace the caliper. they are like 50ea at the parts store.. You can order powdercoated red ones on rockauto for cheap. i had to replace one of mine and if i could have got away for a few days i would have got the red ones instead for like 50-75 for the pair on rock auto.. i think they where powerstop brand iirc.
S
Shane "RedZMonte"
2004 Z16 Z06: Virgin
Re: Brakes dragging
Also, replace both calipers, not just one. The other caliper is the same age as the one that's sticking, and you have to bleed both front brakes anyways...
redzmonte
Re: Brakes dragging
Post by redzmonte »
$26.79 +$10 core ea. Dont forget new Crush washers and if the lines are cracked might as well do the hoses as well.
POWER STOP Part # S4638A Reman; Performance Powder Coated Calipers w/Brackets; Reman
Front; SLE Model; SSEi Model; Sold as a pair of left and right calipers
+ Sold in packs of 2; Price reflects cost of each individual item, not the pack
Shane "RedZMonte"
00bonne
Re: Brakes dragging
Post by 00bonne »
yeah slides look good cleaned and lubed, calipers are original. I'll order new ones.
Thanks
00bonne
Re: Brakes dragging
Post by 00bonne »
ok new calipers and its still dragging
Re: Brakes dragging
What do you mean by dragging? If you go for a drive, is the passenger side much hotter than the driver's side? Or just pulling to the right when you hit the brakes? I guess I didn't probe enough when I first posted?
One thing that can happen in these rubber lines is that a bit of the liner peels up inside, acting like a check valve. Did you replace the rubber flex lines?
00bonne
Re: Brakes dragging
Post by 00bonne »
I can hear the pads rubbing on the passenger side
