Engine Removal
Nitro Nick
Year and Trim: 1999 Pontiac Bonneville SE
Engine Removal
Post by Nitro Nick »
My 1999 Bonneville had a rod bearing fail about 2 years ago. This last spring I just popped a new bearing on the crank and have just kind of run it around the neighborhood. Now that i have saved some money I am trying to remove the engine and perform a full engine rebuild. Four weeks later I still haven't been able to get the engine out. :dontknow:
Does anyone know where the bolts are and how to access them to remove them. Any pictures or diagrams would be GREAT! I have been able to remove the four bolts from the bell housing. The engine is the 3800 V-6 Series 2. Thanks!
Nitro Nick
1999 Bonneville "muscle sedan"
Jfridge92
Re: Engine Removal
Post by Jfridge92 »
I'm not sure of every one, but there's a backwards bolt in the bellhousing that has to be removed from the passengers side with a longgggg extension.
Joseph
1999 Infiniti G20T - Sold
Nitro Nick
Re: Engine Removal
Thanks so much Jfridge92! :) I'll try to get something in there and get it out!
Nitro Nick
grey3800
Year and Trim: 1993 SE L27
Re: Engine Removal
Post by grey3800 »
Ditto on the long extension from the passenger side. I used 3 or 4 extensions in tandem, and then went 'fishing' for that bolt. If i remember correctly it was a 18mm. Have a breaker bar ready too. All other bolts should be accessible from the driver side.
Disconnect the PS pump with hoses from the accessories and tie it back to the firewall area to get some more working room and clear access for your socket extension contraption.
Someone posted a photo of the location awhile back if you need to see it.
-Patrick
Current (work): 1993 SE L27 --- 275,000 miles and counting.
Current (Fun) : 2009 G8 GT; 6-speed manual; 3.45;
Retired(sold): 1988 LE LN3 --- 273,000 miles of fun, Farewell....
J Wikoff
Year and Trim: 1992 SSE
Re: Engine Removal
Post by J Wikoff »
Also unbolt the ac compressor front the engine. Don't forget to unbolt the flywheel from the torque convertor. You can get one bolt at a time through the access cover by the starter.
