Low beam headlight works when it wants to...
BonnieBoy08
Year and Trim: 2003 SSEi
Post by BonnieBoy08 »
My passenger low beam headlight started acting up about a couple weeks ago. At first I thought the bulb was out but then one night it randomly worked again. And now it hasn't lit up while driving for about a week. The bulbs aren't very old at all, I put Plasmaglow Xenon bulbs in it earlier this summer. Here's the odd part, when I lock or unlock the doors with keyless entry it lights up! (the lights blink 3 times and then stay on so you can see around the car at night) I don't know what the option is called. But when I turn the key and start the car it won't light up. Doesn't matter if I turn the switch on or just let the automatic night sensing feature do its thing. High beams work fine. Is there a module or relay in there? I'm lost.
-Nick
younggunls1
Re: Low beam headlight works when it wants to...
Post by younggunls1 »
Lights the flash when you unlock I thought were the high beams? At least on mine they are.
I was having a similar issue but I have HID's.. They require 9-12v to properly run the ballasts and I found my light hookups are only putting out about 7.6-7.8v which Would cause issue with them coming on sometimes but doing a direct wire to the battery fixes this. I don't know if that kind of thing could cause issues with regular halogen bulbs tho.
-Nick
October 2013 Car Of The Month
6000k HID's ~ Custom Halo's and front license plate PONTIAC lit up ~Thrush Turbo Exhaust w/ Dual 3" stainless tips ~ Tinted Headlights and Tail Lights ~ Headlight clear corners ~ 15% tint all around ~ Custom Badging, Lettering, and Painted Engine Cover ~ GXP Spoiler ~ Ported Exhaust Manifolds ~ Shift Kit ~ Custom FWI ~ Tuned with HP Tuners
BonnieBoy08
I’m pretty sure it’s the low beams that flash when you lock or unlock with keyless entry. It’s the 2 inner lights and the brights are the 2 outers. Someone correct me if I’m wrong.
-Nick
younggunls1
Inner are brights
-Nick
bobgto65
2004 Bonneville GXP
Post by bobgto65 »
I had an intermittent problem with the right low beam and it turned out to be the wiring harness from the connector to the bulb socket. I got a new harness from haro and that fixed the problem.
bobgto65
BonnieBoy08
younggunls1 wrote:Inner are brights
Yea you're right, checked it last night. I will have to look into it more this weekend.
-Nick
BonnieBoy08
I had an old bulb laying around I was going to try and as soon as I wiggled the connection around it lit up! That was on Sunday and so far so good. Not sure if it was a loose connection or if I have a harness going bad...time will tell.
-Nick
1tinindian
Year and Trim: 2004 SLE Premier Edition
2005 GXP
Post by 1tinindian »
Put a little dielectric grease on the connector.
Leon
2006 GTO
2005 GXP Bonneville (his) (SOLD)
2004 SLE Bonneville (hers)
2004 SLE Bonneville (sons)
2006 GXP Grand Prix (sons)
1998 SLE GMC Sierra
1991 Yamaha FJ1200
1983 Trans Am (SOLD)
1979 Trans Am
