I might have a problem
Bonneville_ssei_00
- Year and Trim: 2000 Pontiac Bonneville SSEI
Well this weekend I pulled the supercharger off to clean it. After I researched it that your not suppose to clean it. So I was wondering if I ruined the supercharger?
Re: I might have a problem
You might have, how did you clean it? You could have taken the teflon coating off the rotors. Are they gray or bare metal now? You also might have ruined the needle bearings.
Bonneville_ssei_00
The rotors look pretty close to the same before cleaning and I used throttle body cleaner
Bonneville_ssei_00
Would I have to replace the supercharger?
You probably don't need to replace it unless you ruined the bearings. By cleaning it you just lost some of the efficiency.
- MattStrike
- Year and Trim: '99 Montana
'04 Dirtymax
'97 Camaro
As long as it didn't get soaked overnight in gas, ask me how I know...
Boost addict
The Fleet:
'97 Camaro - Top swap
'05 STS - V8, AWD, her DD
'92 Trofeo - Fair weather DD
'99 Montana - top swap 3800
Current project:
Something cool, trust me.
Upcoming projects:
'92 Bonneville SSE
'87 LeSabre T-type
'67 LeSabre
Gone to greener pastures:
'97 LeSabre - Top swap
RIP:
'86 LeSabre - pictures
'93 SE - L67
The Fleet:
Current project:
Upcoming projects:
'92 Bonneville SSE
'87 LeSabre T-type
'67 LeSabre
RIP:
'93 SE - L67
GotBonneBWitMe
- SSEi Member
- Year and Trim: 96 SSEI
MattStrike wrote:As long as it didn't get soaked overnight in gas, ask me how I know...
Well, how do you know that??
- MattStrike
'04 Dirtymax
'97 Camaro
Because I did it, and the gas made the rotor coating peel off. Yup.
Boost addict
The Fleet:
Current project:
Upcoming projects:
'92 Bonneville SSE
'87 LeSabre T-type
'67 LeSabre
RIP:
'93 SE - L67
The Fleet:
Current project:
Upcoming projects:
'92 Bonneville SSE
'87 LeSabre T-type
'67 LeSabre
RIP:
'93 SE - L67
Bonneville_ssei_00
How hard would it be to replace the needle bearings?
Easier to replace the whole SC. I sell them for $100.
Bonneville_ssei_00
What would happen if I put it back on and bearing are bad?
How deep of a cleaning did you do? Just remove it and clean the carbon off the exterior surfaces? Or did you tear it completely apart, and have to deal with the S/C oil?
If the needle bearings are shot, you'll hear it.
Bonneville_ssei_00
I just cleaned the area behind the throttle body
You should be alright. If it starts making funny noises, then it's time to be concerned...
