Exhaust tips? Size?
Dannyg420
Year and Trim: 2003 Bonneville SE
Exhaust tips? Size?
Post by Dannyg420 »
i have the sle/seei exhaust and a glasspack to replace the resonator and 2 magnfalow muflers. now all i need is some tips so i can get it all put on. my question is what tips do you guys think would look best and what size? ikno ill probably need 2.5in inlet due to my mufflers being that size but what about the outlet and length any ideas?
2003 Bonneville SE.....Intense Fenderwell intake....Magnaflow mufflers....glasspack resonator....grand prix wheels....rear 5% limo tint front 18% tint......Kenwood Headunit....mb quart tweeters,doors, 6x9s powered by autotek 1400 watt 4channel amp.....2 12in Alpine Type Rs 1000rms each powered by 1500 rms Mb quart mono RA1500.1
Wes
Year and Trim: 2002 Buick Park Ave
Re: Exhaust tips? Size?
Post by Wes »
There is such a wide variety of options to choose from. What is best is something only you can answer. Do some searches of what others have done, and go from there. It is all about what YOU like best.
yourgrandma wrote:High
redzmonte
Year and Trim: 2000 SSEI
Post by redzmonte »
if your mufflers are 2.5" in/out then you will want to get a 2.5" but 2.25" should also be fine. Any decent muffler shop will make either work.
Shane "RedZMonte"
2004 Z16 Z06: Virgin
Dannyg420
Post by Dannyg420 »
Yea but what length tips should i be looking at if i want them to just stick out mayb a inch or 2 from the bumper
KelvinVV
Year and Trim: 2002 Pontiac Bonneville SSEi
Member #8782
Post by KelvinVV »
Mine are Kool Vue oval exhaust tips. They came on the car when I bought it and I think they look pretty good. I hate the name, though. "Kool Vue" sounds like it was thought up by 5th graders lol
Kelvin VanderVeen
PERFORMANCE MODS
180 DEGREE THERMOSTAT, AUTOLITE 104'S, ZZP VOLTAGE BOOSTER
APPEARANCE MODS
LED INTERIOR LIGHTS, TAN INTERIOR TRIM, CLEARED CORNERS
:bpylons:
gweg_b
Year and Trim: 95 LeSabre Custom
01 Bonneville SSEi
09 G8 GT
Post by gweg_b »
I agree with Wes, tips are something you have to like. I went through 3 sets of tips on my LeSabre before I found a set that I completely fell in love with.
I have a unique set of tips I plan on getting installed on the Bonneville, as soon as I can find a shop that doesn't think I'm crazy! :lol:
As for length, your best bet is to get under the car and do some measurements: how far from the pipe to the edge of the bumper, and then from there how far you want it to stick out. From there, find the tips in the right length you need. That's pretty much how I went about it on the LeSabre.
- Greg | -- Project Prasinos -- |
1995 LeSabre Custom: 312K Miles | Custom K&N CAI | Edelbrock SDT Muffler | Camaro Tips | 180 T-stat | LED Interior
& Exterior | 20% Tint | PA Grill & Portholes | Limited Trim | GTP Rims | Ported LIM | Plus Many More Mods | Restoration Thread
2001 Bonneville SSEi: 225K Miles | Instense FWI | Intense MPS (3.4") | 180 T-stat | ZZP Plog | Ported Rear Manifold |
ZZP 3" Downpipe | Magnaflow Cat | Retrofitted HIDs | GenV M90 | GXP Brake Upgrade | 35% Tint | Plus Many More Mods |
2005 Bonneville GXP: 101K Miles | Custom FWI
2009 G8 GT: 89K Miles | 35% Tint | Roto-Fab CAI | SOLO Mach Exhaust | BMR Tunnel Brace | BMR Sub Frames | BMR STB |
Kooks Headers | QTP Electric Cutouts | BMR Sway Bars | Elite Engineering Catch Can | Innovative Dual Wideband Kit
1984 Caprice Classic Wagon: 86K Miles | Restoration Project
Dannyg420
Post by Dannyg420 »
Alright thanks guys
motopsyco
Year and Trim: 1992 SE
Post by motopsyco »
also your tip length doesnt have to be very accurate, just plan on getting something longer than what you need, that way you can adjust the length when you put them on, and worst case scenario you can trim off a little off of your pipes to get the desired look your after.
