We are all familiar with the water barrier problems and the trunk lid/rear light casing problems producing leaks in the cabin and trunk of these vehicles. However after fixing my driver side forward door water barrier & rear passenger side (this one was fine when I opened it) I was stumped. So today when I went back into the fuel tank to fix the gasket I broke when replacing the level sending unit, I found this condensation, and decided to try something new:
I had to pull up the carpet anyways, and I found that there was condensation on the whole driver side of the trunk with some small pools in a few places. The battery location and passenger side floor were also refilled.
I slowly poured a gallon of water over the rear of the car where I thought it might be coming in. Thankfully, the gas cap area was not problematic. But when it hit the channel for the driver side trunk lid gasket, it instantly started a fast drip right here:
Later I investigated, cleaned with isopropyl alcohol and used silicone sealant on this part above the drip and on the seam underneath - I did the passenger side too as it looked a bit bad as well:
I tested the fix 2 hours later - no leak! Problem solved, maybe. I hope this helps!
