It has probably been asked and answered already but I couldn't find the info.
What years/makes/models have compatible ICM/PCM with my 1992 SSEi??
There are precious JY around me and I'm going to need every bit of info I can get.
1992 ICM & PCM compatibility question
- hammerheart
- SSE Member
- Year and Trim: 1992 Bonneville SSEi
- 95naSTA
- Year and Trim: 95 SLE
Re: 1992 ICM & PCM compatibility question
Any 92+ 3800 ICM and coils will work.
The 92 PCM is 92 specific though. And unless the donor car has the same engine and trans combo, you'll need to swap the removeable memcal over from your car.
- Wes
- Posts like a Northstar
- Year and Trim: 2002 Buick Park Ave
92, and 93 PCMs are the same. Just use your original E-prom.
yourgrandma wrote:High
motopsyco
- SSEi Member
- Year and Trim: 1992 SE
+1 on wes's info. The 92-93 have the same systom, 94 - 95 I believe was the whole obd 1.5 system I think. So if you can find from a 92-93 then you should be fine. there are however other models that should be the same like the buick park avenue, and I think the olds 98 (might be a diff model though).
- spoiledred94
Olds "88" I think. I pulled a JY PCM from one for my 94 SE. It had the 3.06 Final Drive Ratio I needed. Sinister Performance does a good flash for these PCMs. I had an ICM left over from my 94 after I got my 01 SSEi. The part numbers for the 2 years matched right up
great car. Wrecked
Burnt Bonny.
great car. Wrecked
Burnt Bonny.
- Wes
Correct, the 98 is the same as the park ave. Both C bodies. The olds 88 (H body) will work as well in those years too.motopsyco wrote:+1 on wes's info. The 92-93 have the same systom, 94 - 95 I believe was the whole obd 1.5 system I think. So if you can find from a 92-93 then you should be fine. there are however other models that should be the same like the buick park avenue, and I think the olds 98 (might be a diff model though).
And correct again, the 94-95 are different. Last years to have the e-prom, but had the hybrid OBD 1.5.
