adding 180 stat
95se
Year and Trim: 1995 se bonnie
adding 180 stat
Post by 95se »
Do i need to do a manual over ride on my 95 with a 180 t-stat?
1995 se
128,101
custom FWI
rt-95 rims look kinda like crosslaces
6000k hids
f- body muffler dual output
96-99 headlight conversion, clear markers
gweg_b
Year and Trim: 95 LeSabre Custom
01 Bonneville SSEi
09 G8 GT
Re: adding 180 stat
Post by gweg_b »
You don't need one, but they can be handy if you run a lot at the track. My LeSabre has always run with a 180 with no over ride, and I ran for years on the Bonneville with a 180 without having the computer adjusted.
- Greg | -- Project Prasinos -- |
1995 LeSabre Custom: 312K Miles | Custom K&N CAI | Edelbrock SDT Muffler | Camaro Tips | 180 T-stat | LED Interior
& Exterior | 20% Tint | PA Grill & Portholes | Limited Trim | GTP Rims | Ported LIM | Plus Many More Mods | Restoration Thread
2001 Bonneville SSEi: 225K Miles | Instense FWI | Intense MPS (3.4") | 180 T-stat | ZZP Plog | Ported Rear Manifold |
ZZP 3" Downpipe | Magnaflow Cat | Retrofitted HIDs | GenV M90 | GXP Brake Upgrade | 35% Tint | Plus Many More Mods |
2005 Bonneville GXP: 101K Miles | Custom FWI
2009 G8 GT: 89K Miles | 35% Tint | Roto-Fab CAI | SOLO Mach Exhaust | BMR Tunnel Brace | BMR Sub Frames | BMR STB |
Kooks Headers | QTP Electric Cutouts | BMR Sway Bars | Elite Engineering Catch Can | Innovative Dual Wideband Kit
1984 Caprice Classic Wagon: 86K Miles | Restoration Project
95se
Re: adding 180 stat
Post by 95se »
i do run at the track for fun almost every friday, so for the summer and early fall it will help me there, but being in ohio with sub zero temps at times ill put the 195 back in for winter
1995 se
128,101
custom FWI
6000k hids
Re: adding 180 stat
180 is plenty hot, I never switched mine out and never had issues even when it was -30°.
95se
Re: adding 180 stat
Post by 95se »
Thanks for the advice!
1995 se
128,101
custom FWI
6000k hids
redzmonte
Year and Trim: 2000 SSEI
Re: adding 180 stat
Post by redzmonte »
I just installed a 180* on my 2000, nothing needed other then stat and gasket. Takes 5 min to swap and minimal spill if you are careful.
Shane "RedZMonte"
2004 Z16 Z06: Virgin
95se
Re: adding 180 stat
Post by 95se »
So why have alot of people acted like it was a big deal if you dont have the fans set for the right temp?
1995 se
128,101
custom FWI
6000k hids
2003 SSEi
Year and Trim: 2003 SSEi.
LOTS of Mods
Re: adding 180 stat
Post by 2003 SSEi »
because the car will be the normal temp when the fans are not on
Re: adding 180 stat
The only time the motor will run at 180* or near it, is on the highway. Otherwise all the other times the fans will come on like normal which is in the 220* range.
freneticburn
Year and Trim: 1998 Bonneville SE?
Re: adding 180 stat
Post by freneticburn »
95se wrote:So why have alot of people acted like it was a big deal if you dont have the fans set for the right temp?
If you don't set the fans then it's kind of pointless. It will obviously keep the temperature down a bit inside the engine, and most would correctly state that's all that really matters, but when that coolant gets released into the radiator it doesn't get cooled down as much as it should before it eventually re-enters the engine. If you're cruising down the interstate it won't matter as there will be plenty of airflow cooling your radiator but sitting in traffic or at a race track the temps are gonna still be quite high.
At least that's my limited understanding of it. I'm no mechanic or thermal engineer though :P
Re: adding 180 stat
:stupid:
Did some kind of message go out to the old members? I've seen more than a few re-appear the past couple days.
Re: adding 180 stat
00Beast wrote: Did some kind of message go out to the old members? I've seen more than a few re-appear the past couple days.
Not sure. Would be pretty cool though. Kinda miss when this place bumped a little. Hahaha
:offtopic:
redzmonte
Re: adding 180 stat
Post by redzmonte »
160* stat WILL require reprogramming of the ecu. I swapped mine trying to lower my combustion temps and reduce my NOx readings.. didnt do much but makes me feel better on 90-100* days..
Shane "RedZMonte"
1oldman
Re: adding 180 stat
Post by 1oldman »
Don't want to hi-jack the thread, but I put a 180 thermostat in my ole 92 SSE quite some time back - before I joined the forum and it did not like it at all. It would not come up to operating temperature. I had to put the 195 back in.
My question is, since the cooling system on the '05 that hopefully I pick up tomorrow, would it really be a good idea to change to a 180 while it's torn apart, or just leave the 195 thermostat in it, or is it just an opinion that it should be a 180, not a 195?
Thanks - BC
95se
Re: adding 180 stat
Post by 95se »
^^^^oldman^^^^^ hopefully mine being a series 2 it doesnt act up like yours, well see i just got a themostat
1995 se
128,101
custom FWI
6000k hids
RJolly87
1994 Buick Regal Custom
Re: adding 180 stat
Post by RJolly87 »
Quite honestly, I ran a 180* for a while, and noticed no difference. I think the only difference would be where the gauge rides on the highway, or how cool the car runs with the A/C on (which runs the fans on high usually). The main benefit is to the supercharged engines, as when they heat soak, they like to preignite (aka Knock), and this helps keep that at bay. The NA engines can stand to run hot, and some actually run better from it.
And as far as the car never heating up with a 180*, either it was friggin cold, or something was wrong with your thermostat. In cases like that, if it is that cold, you would do well to block off some of the radiator during the winter to keep heat in the engine.
as mentioned, to get the most, a PCM tune is recommended to bring down the turn on temp, to make the most of it, but an override works also. An override can trip a code on OBD2. On a stock pcm, extended stints below 170* (like with a 160* thermostat) will likely trip a code (too cold for too long).
~Randall~
Re: adding 180 stat
1oldman wrote:Don't want to hi-jack the thread, but I put a 180 thermostat in my ole 92 SSE quite some time back - before I joined the forum and it did not like it at all. It would not come up to operating temperature. I had to put the 195 back in.
Thanks - BC
She'll run hot anyways. Unless you do a lot of open road driving I'd just leave the 195 in.
J Wikoff
Year and Trim: 1992 SSE
Re: adding 180 stat
Post by J Wikoff »
The PCM adjustment doesn't have much to do with the fan turn-on temps as much as it has to do with when the PCM stops trying to make the engine warmer VIA fueling (and maybe timing). I've got a 160 and a chip tuned for it. Typically, it sits at 170-180 in town driving.
95se
Re: adding 180 stat
Post by 95se »
Just put the 180 in today, so far the cars running good and cooler, so ill give it a few days and see
1995 se
128,101
custom FWI
6000k hids
1oldman
Re: adding 180 stat
Post by 1oldman »
Thanks - BC
I had it in for over a month. It never got past where I thought 190 was. It never even made it to the middle of the temp gage (200?), with or without the A/C. I took it out because I was concerned about what happens to the oil and engine when they never reach operating temperature. - BC
