Hockey puck mount bolt
- spoiledred94
- Posts like a Northstar
Is A mark 5 quality bolt safe enough for the puck mount?
great car. Wrecked
Burnt Bonny.
great car. Wrecked
Burnt Bonny.
Re: Hockey puck mount bolt
Should be. Most that I've seen have been Grade 5. I used Grade 8's on the two I've made, but it's overkill. Only a couple more dollars, though.
- spoiledred94
Thanks Jake. My True Value quoted me for the five. I will look for the 8 jic.
L8tr
L8tr
great car. Wrecked
Burnt Bonny.
great car. Wrecked
Burnt Bonny.
- spoiledred94
I bought the "mark 5" bolt and 3 wide washers for the upside and a smaller washer for the bottom side, as well as a bushing for the bottom side (bolt head side) as well as 2 lock nuts foe the top/
Got it all home and the bolt head says 3097A, no marks at all. So I need to go somewhere else for the 5 or hopefully the 8
great car. Wrecked
Burnt Bonny.
great car. Wrecked
Burnt Bonny.
You don't need any fancy bolt. The first time I made one I used threaded rod and it held up for years.
- spoiledred94
Mine stripped up. I am not sure what quality I put in the first time, but I went back and got what they sold me as a 5 yesterday and it wasn't. so I have to go back. I might of stripped it putting it on originally but I don't remember doing that all
great car. Wrecked
Burnt Bonny.
great car. Wrecked
Burnt Bonny.
- spoiledred94
That store didn't carry any Mark 5's or 8's in a 7" or 8" at all. I found a 5; 7" and the rest at The Ace in the next neighborhood over. The other thing wanted to post was that I put the original bolt threaded end up. Which I won't do this time. Thanks
great car. Wrecked
Burnt Bonny.
great car. Wrecked
Burnt Bonny.
I would put the threaded end on top. That way you don't have anything extra hanging down...
- spoiledred94
00Beast wrote:I would put the threaded end on top. That way you don't have anything extra hanging down...
Other than hanging down and being in the line of some object what difference does it make?
great car. Wrecked
Burnt Bonny.
great car. Wrecked
Burnt Bonny.
Not much.
- spoiledred94
the mid point of rotation would be the same in either configuration. And there would be differences in the physical forces effecting the integrity of da bolt. but IDK which way would keep the nut tighter on the thread.
I bought a new 5-7" bolt and washers and a cheap grommet along with a reg nut and a lock nut. If the old bolt comes out easily Ill have it done before work.
Thanks guys your great, no really
great car. Wrecked
Burnt Bonny.
great car. Wrecked
Burnt Bonny.
It's pulling on both ends of the bolt regardless. It's whether it's easier to install one way or the other, and I've found it's a lot easier to install bottom up, as well as keep maximum ground clearance.
- spoiledred94
I pulled the original bolt. It was actually fine. I thought it was stripped but what was happening was that my rubber bushing was worn and jamming the bolt from being removed. I replaced it with a shorter 7" (Mark V). The fit is tighter, more reliable (Nut, Lock Nut, Lock Tite) and the bushing is new and separated with washers.
Any way the ride is great. No vibrations, no thunking in and out of gears
great car. Wrecked
Burnt Bonny.
great car. Wrecked
Burnt Bonny.
rrounds
- Posts like an L36
- Year and Trim: 2000 SSEi
I made the first solid mount for a 2000 SSEI back in 2001 and I put over 220k miles on it with just a grade 5 bolt. Just sold it last week, going to miss that car.
ROD
ROD
2000 SSEI (SOLD)
rods789 at comcast.net
PB 14.474 @ 96.248 PB 60' 2.168
180 therm AEM DRYFLOW Air Filters
3.33 pulley 3" cat back exhaust
custom solid front motor mount
custom 6" (BIG) intake
__WCBF '06, '07, '08, '11 survivor__
And considering your wife broke the Subframe driving that car, I wouldn't be too worried, lol.
xcbullet
- SSEi Member
- Year and Trim: 2000 SE, transg kit & B&M trans cooler
Thinking about doings this mod but worried might be to stiff. Feel the need after shift kit, get rid of the rubber band effect. Was wondering if just a new better after market mount be good, if there are any.
- spoiledred94
XCBULLET, I have a knack for confounding simple things, which this mount is. Review some threads here about it. It's straightforward and I like the added quickness if I'm not imagining it.
great car. Wrecked
Burnt Bonny.
great car. Wrecked
Burnt Bonny.
It's not too stiff. Just make sure you get a good bushing under the head of the bolt on the subframe.
- spoiledred94
and put washers on either side!!
great car. Wrecked
Burnt Bonny.
great car. Wrecked
Burnt Bonny.
