Alternator
Alternator
Could a weak alternator cause ac blower to blow weak?. Got my alternator tested and it was weak on loads
- RJolly87
Re: Alternator
It could, however it would be caused by the voltage dropping due to more load than the alternator can keep up with, which you would see on your voltage indicator. It would also be apparent through other accessories on the vehicle.
The number one offender, however, is this:
http://www.pontiacbonnevilleclub.com/fo ... c2432.html
~Randall~
Re: Alternator
If your alternator is weak, replace it. It will affect everything, and will drag down on an otherwise good battery.
