Problem is I need to pass emissions test next month.
I want to check the evap canister, solenoid and the lines. (are there 2 solenoids?) Is the evap canister and solenoid accessible without dropping the fuel tank? Where do I get to it? (I am guessing from the rear driver side wheel well?)
Also, when checking the evap solenoid in engine compartment, I broke the U-shaped tube which runs from the solenoid to the throttle body. It was extremely brittle. You can see the tube to the left of the arrow in the following picture:
Can I replace this tube with rubber hose? (I dont think this was the cause of the code).
Any other hints chasing down this code?
thanks
