Hockey puck mount. Good and bad.
rmorton
Year and Trim: 2000 SSEi Stock.
Post by rmorton »
Replaced the busted mushroom with the hockey pucks yesterday. Shifts much smoother. Especially from park to drive. Feels more responsive. I love it!
However, from about 1200 - 1800 rpm I'm getting engine vibration inside the cab pretty bad. Enough that it is audible and stuff in the cup holder rattles. Is it possible that I tightened the bolt down too much? I'm thinking about loosing it up some.
From bottom up I used: grade 5 bolt head, washer, stabilizer link bushing, washer, subframe, 3 pucks, stack of washers, mount, nylon nut.
Any thoughts?
BonnieBoy08
Year and Trim: 2003 SSEi
Re: Hockey puck mount. Good and bad.
Post by BonnieBoy08 »
Everyone gets the vibration that does this. Mine smooths out nicely at freeway cruising speeds of 65mph or more though. I don't know that loosening the nut would be the greatest idea, there's alot of torque and stress on there so it should be tight. In my opinion the pros outweigh the cons and I've learned to live with it, mine actually sounds like an exhaust rumble inside ;)
-Nick
gweg_b
Year and Trim: 95 LeSabre Custom
01 Bonneville SSEi
09 G8 GT
Post by gweg_b »
Yeah, I believe everyone that does this gets a slight vibration. Mine has it, but after almost a year, I don't even notice it anymore. I still plan to add another bushing and a few more washers on it this summer, just to level it up a bit more. But, give it some time, eventually you'll get completely used to it, especially now that you can put more power to the wheels! :wink:
- Greg | -- Project Prasinos -- |
1995 LeSabre Custom: 312K Miles | Custom K&N CAI | Edelbrock SDT Muffler | Camaro Tips | 180 T-stat | LED Interior
& Exterior | 20% Tint | PA Grill & Portholes | Limited Trim | GTP Rims | Ported LIM | Plus Many More Mods | Restoration Thread
2001 Bonneville SSEi: 225K Miles | Instense FWI | Intense MPS (3.4") | 180 T-stat | ZZP Plog | Ported Rear Manifold |
ZZP 3" Downpipe | Magnaflow Cat | Retrofitted HIDs | GenV M90 | GXP Brake Upgrade | 35% Tint | Plus Many More Mods |
2005 Bonneville GXP: 101K Miles | Custom FWI
2009 G8 GT: 89K Miles | 35% Tint | Roto-Fab CAI | SOLO Mach Exhaust | BMR Tunnel Brace | BMR Sub Frames | BMR STB |
Kooks Headers | QTP Electric Cutouts | BMR Sway Bars | Elite Engineering Catch Can | Innovative Dual Wideband Kit
1984 Caprice Classic Wagon: 86K Miles | Restoration Project
FasGP
Year and Trim: Pullied Clean 2k Black SSEi...
Post by FasGP »
There is no bad. Vibration = feeling of power.
There is no question it drives better. Stock mount = grandpa car.
2000 SSEi - Hoddmann ported LIM and GenIII, 3.2 MPS, 1.8 SLP's, SSAC's, 3" Catback, AL104, 180tstat, Custom FWI, Cartuned
crash93ssei
Post by crash93ssei »
You could try putting another stabalizer bushing between the mount and top nut, that should help some as well.
yourgrandma
Year and Trim: '02 SSEi
Post by yourgrandma »
Agreed. Add another bushing on top. Mines pretty gruff but I have a very stupid engine.
rmorton
Post by rmorton »
I see. Well, I can probably live with it like most of you have. I love everything about it except that vibe. Might add another bushing under the bolt head and see what happens when I get time.
Tanks for da feedback.
Hans
Year and Trim: '07 MDX | '13 TL | '06 GTO
Post by Hans »
I'm torn.
I had the hockey puck mount on the 01 with some bushings but still had some significant vibration.
On my current SSEi, I have gone through 2 mounts so far in the last couple years over 20,000 miles or so. The Anchor mounts seem to last 8000-12000 miles in my experience. Thankfully they have lifetime warranty but it is a pain to swap out every 3-6 months.
I may have worn mounts which are making them fail faster, not sure.
Its your call, no real "good" option IMO.
EDIT: I should also add, yes, if you do a hockey puck it will last forever. You need rubber bushings on both sides of the top of the bolt. This helps a little but you get some rattles at certain RPMs in the cabin.
yonkerss
Year and Trim: '05 SLE
Post by yonkerss »
I had a hockey puck mount I removed it, didn't like the vibration at all with my driving speeds. I put in an anchor mount. About 15k miles and still good but I bought local so when it fails I'll get another at no charge.
Scott
'05 SLE, Crimson Tintcoat, 89K
Mechanical: FWI, FelPro LIM and Valve Cover Gaskets, Ported LIM, Prestone Green Coolant, 180 Thermostat
Exterior: Tinted - 35% Front, 20% Rear
Interior: GXP Carbon Fiber Upgrade, Tinted Reflectors
Archon
Post by Archon »
I hated the vibration that I got from the solid mount, and tried various things to subdue it. What finally worked was using some rubber grommets that I had laying around. It can barely be felt now.
I have an old endlink bushing under mine and I don't even notice it anymore, but we just did one on my buddy's 05 SLE yesterday and he's not a huge fan. Might throw another endlink bushing on top if he doesn't get used to it, and see if that mellows it out.
yonkerss
Post by yonkerss »
I tried about 4 variations of bushings and rubber pieces and some where better then others without a doubt. I think I still have most of the parts around if anyone wants it. Cover shipping and its yours.
Scott
gweg_b
01 Bonneville SSEi
09 G8 GT
Post by gweg_b »
I think I got used to it more because I got used to the nasty vibration my LeSabre would develop at higher speeds (50mph+). I had that looked into several times, and no one could find the problem, so I just learned to ignore it. Because of that, the vibrations I get from the hockey pucks are nothing.
Of course, everyone is different. I just didn't want to keep replacing the factory mount every 3,000 miles.
redzmonte
Year and Trim: 2000 SSEI
Post by redzmonte »
I have Bolt/washer/subframe/3 pucks/couple washers/mount/rubber end link bushing/washer/lock nut.
i added the end link bushing in mine and it took almost any vibration away..before i put it in the vibs were pretty strong in the car to the point i didnt like it, and i will sacrifice quite a bit for performance but it was too much. still there a tiny bit but not enought to be any concern to me (very small ammount) which is to be expected with basically a solid mount.
Shane "RedZMonte"
2004 Z16 Z06: Virgin
