Power steering pressure switch
pontiacsteve22
Year and Trim: 1990 bonneville le
Post by pontiacsteve22 »
Hi just curious what tools do i need to remove this switch.Also is there anything special like maybe bleeding after removal i need to do, mine is leaking and i like to replace it.Cant stand oil leaks, thanks in advance guys.
MattStrike
Year and Trim: '99 Montana
'04 Dirtymax
'97 Camaro
'92 Trofeo
Re: Power steering pressure switch
Post by MattStrike »
http://www.rockauto.com/catalog/moreinf ... cc=1247318
Looks like there is a nut behind the larger metal sleeve. The power steering will leak out a little while it's off, but will pretty much self bleed (it may grind like a wookie growls for a bit, just keep the fluid topped off).
Boost addict
The Fleet:
'97 Camaro - Top swap
'05 STS - V8, AWD, her DD
'92 Trofeo - Fair weather DD
'99 Montana - top swap 3800
Current project:
Something cool, trust me.
Upcoming projects:
'92 Bonneville SSE
'87 LeSabre T-type
'67 LeSabre
Gone to greener pastures:
'97 LeSabre - Top swap
RIP:
'86 LeSabre - pictures
'93 SE - L67
pontiacsteve22
GREAT pic and advice, the nut underneath is where you can put a wrench on it.Thanks again, you are clearly a awesome person and glad too hear your words of wisdom :beerchug: i owe you a beer.
