ZZP downpipe question.
BRUTE FORCE
Year and Trim: 2000 Pontiac Bonneville SSEI
Post by BRUTE FORCE »
Hey guys, I just bought a ZZP downpipe and had it installed today. I deleted the cat and welded it to the resonator. I wanted to know if this setup will help in performance gains.
nubuilder
Re: ZZP downpipe question.
Post by nubuilder »
I don't have one, but it seems that the consensus is that it does help (especially the 3" on a S/C'd car). Hopefully you got a o2 simulator or had it tuned out.
Matthew
I am assuming it's a 3 inch. Then yes, you should free up a bit of power. You should get the front manifold to match with it.
nubuilder
Post by nubuilder »
Would you suggest a ported front manifold or a P-log? Does one need to worry about the crossover pipe at all?
The only reason I ask is I just wonder if it is better in the long run to just go with headers VS the cost of a DP, ported manifold(s), and possibly crossover.
Matthew
Did you look at the inside of the stocker? It can't not help.
Question is: Do you feel any gains?
Alpine_jake
Post by Alpine_jake »
you should feel a gain. i did the power log and 3 inch catless dp and it main a very noticeable gain
l67 swap; 3'DP, power log, CAI, 10.5 wires, 3.5" pulley, autolite 104s, canned tune, 180 thermo, 2 Alpine type Xs, ARC Audio XDi 2000, Big three-0/1 , couple Red Tops, alpine x303, cleared lights, custom trunk.
