trunk release
siixmac7414
Year and Trim: 2000 Pontiac Bonneville SSEI
trunk release
Post by siixmac7414 »
not sure if this is the right place for this but my whoever had my vehicle before me decided to dig out the key hole to the trunk and the trunk release button is not working. i checked the relay and it was missing so i took the relay from the park lamp and swapped them...nothing anything ideas?
siixmac7414
Re: trunk release
Nothing?
drift7one
Year and Trim: 2002 Pontiac Bonneville SE
Re: trunk release
Post by drift7one »
maybe try reposting this in the General Discussion section. might get some more eyes on it up there. Id help, but I dont know what would be the next step.
drift7one
Rich- Member #6668
Golden Hurricane
| Cleared Headlights | 20% Tinted Windows | AVS VentVisors | Viper 2-Way Alarm System | Garmin GPS Navigation |
| DDM Tuning 8000k 35w HID Headlights | Nokya Hyper Yellow 2500K Fog Lights | Black PlastiDip Accents & Badges |
david
Year and Trim: 2000 bonneville sle , 2002 gtp
Re: trunk release
Post by david »
Use a test light to see if you have power to the wires?
What does it profit a man to gain the whole world and lose his soul.
Archon
Re: trunk release
Post by Archon »
Do you hear a click from the relay when you depress the button? Can you get the trunk open? If so, have you checked to see if the connector is still attached to the latch?
siixmac7414
Re: trunk release
Archon wrote:Do you hear a click from the relay when you depress the button? Can you get the trunk open? If so, have you checked to see if the connector is still attached to the latch?
i dont hear anything at all and i havent figured out a way to get into the trunk yet
Archon
Re: trunk release
Post by Archon »
So, it was relay 52 that was missing? Which one did you swap in. I'll check on my car and see if the relays are the same.
[The extension gif has been deactivated and can no longer be displayed.]
siixmac7414
Re: trunk release
Archon wrote:So, it was relay 52 that was missing? Which one did you swap in. I'll check on my car and see if the relays are the same.
40
Archon
Re: trunk release
Post by Archon »
Those relays are compatible. Try removing the relay for the trunk release and see if at least 2 of the terminals have 12 volts. If they do, run a jumper wire between points 30 and 87, using the attached picture. Go by where the arrows are, not the end of the jumper toward the top of the picture. That should open the trunk. If it does, the problem lies between the button and the relay. If it doesn't, the problem is between the relay and the trunk release.
