P0446 & P0446 (pd) evap code
YoungBonne12
- Year and Trim: 2002 Bonneville SSEI
so i've had an SES code for awhile now, along with poor gas mileage (18.8), and i just recently got the scanner from our shop. i scanned the codes and it gave me two codes. A P0446 & P0446 (pd). both said "EVAP emission control system vent circuit malfunction" .... i have 0 idea where to go from here and i could definitely use some help guys. please and thank you. along with the ses, i am getting a service vehicle soon alert which i will address in another topic. thanks guys!
2002 Bonnie SSEI debadged and pieced together.
Daily Driver. 46,xxx original
Alpine 136bt
JX 360/4, Kenwood 6x9, infinity 6.5
Pdx 1.1000 on a W7 12"
1996 Viper GTS - The Rare Drive
11k miles
Autonetworkinc.com .... go buy something ;)
Alpine 136bt
11k miles
Re: P0446 & P0446 (pd) evap code
I would start by inspecting the vacuume harness that connects from the TB, to the Evap sensor, LIM and around to the MAP and Fuel pressure Reg. common to have leaks.
Shane "RedZMonte"
2004 Z16 Z06: Virgin
Shane "RedZMonte"
- CMNTMXR57
Daily Drivers:
2011 Camaro SS
YoungBonne12
No, both codes were P0446. So it is possible that all my problems could be from a loss of vacuum in the system?
Alpine 136bt
11k miles
Alpine 136bt
11k miles
- CMNTMXR57
I'll have to look up the specifics of it. P0440, P0442, and P0446 are all EVAP related codes that are the inverse of one another. One is for not being able to maintain pressure and decay at a predetermined rate, the other is that it won't vent at all when commanded to. I just never remember which is which.
Daily Drivers:
2011 Camaro SS
check your other post for loss of boost. they are most likely all one problem. I posted the info on the vac harnesses and what not in the other post.
Shane "RedZMonte"
YoungBonne12
Thank you guys. That would be great if it was all from these weathered hoses. I've told my step-dad about everything and we're going to look around for hoses and what not to see if that solves any problems. If after replacing the hoses, there is still problems, I will be back with more info
Alpine 136bt
11k miles
Alpine 136bt
11k miles
YoungBonne12
my supercharger problem is fixed. and i just replaced the purge solenoid, but to no avail. since it is most likely an electrical issue (circuit malfunction) what do i look for next? because nobody wants to bite the bullet and take it to a dealer
Alpine 136bt
11k miles
Alpine 136bt
11k miles
