GXP cluster in SSEi
sandrock
GXP cluster in SSEi
Post by sandrock »
If I were to swap to a GXP cluster because, say, I like the font on the gauges as well as the white background...what all would I have to do to make the battery gauge work like a battery gauge instead of a wigged-out battery gauge on meth?
If I were to do this, I'd of course have to add a vac/boost gauge somewhere :btruestory:
wake
Year and Trim: 96 olds cutlass supreme 4 door
Re: GXP cluster in SSEi
Post by wake »
you could also just order white face guage inlays for the SSEi cluster :btruestory:
just a thought
:headbang:LUCAS Image Member # 534.
96 olds cutlass supreme SL 4 door 3100 4t60 *3.33 gears* *Fe1* 115K bone stock DD
The volt gauge will work properly because the cluster pulls data from the PCM.
The only thing you will need to modify is the wiring for the low coolant sensor.
See here: http://www.pontiacbonnevilleclub.com/fo ... 21717.html
1tinindian
Year and Trim: 2004 SLE Premier Edition
2005 GXP
Post by 1tinindian »
They are silver faced, not white.
2006 GTO
2005 GXP Bonneville (his) (SOLD)
2004 SLE Bonneville (hers)
2004 SLE Bonneville (sons)
2006 GXP Grand Prix (sons)
1998 SLE GMC Sierra
1991 Yamaha FJ1200
1983 Trans Am (SOLD)
1979 Trans Am
SSEiMan01
Post by SSEiMan01 »
They're indeed more silvery. Aeroforce can be used as a boost gauge. ;)
James May wrote:Hello.
swampthing
Post by swampthing »
According to haros thread you will not have the correct mileage if that matters to you
Current fleet:
sandrock
Post by sandrock »
The engine has ZERO miles. The transmission was rebuilt sometime in the past. Mileage won't matter to me too much.
sandrock
Post by sandrock »
Bookmarked. That was quick n' dirty and functional. I may use the writeup as a base for my later mods, one that involves an intercooler and a possible warning of low intercooler coolant, or low maybe water/meth tank :btruestory:
yourgrandma
Year and Trim: '02 SSEi
Post by yourgrandma »
:btruestory: is getting a lot of use in this thread.
SSEiMan01
Post by SSEiMan01 »
:btruestory:
sandrock
Post by sandrock »
I pulled the trigger on it. Should be here this tuesday!
sandrock
Post by sandrock »
Got it. Man it looks soooooo good. MUCH better than the stock cluster, and reminds me a lot of the newer Grand Prix gauge font.
No pics yet, will save that for the unveiling once the project is done. As for the coolant message, I'm going to solder a wire straight to the board, and run it down to the grounding point on the driver kick panel. For now it'll stay grounded, but once I get an idea for what I want to do with the coolant message, I can easily get to the needed trigger wire.
