The first time it came on my mechanic replaced the Catalytic Converter. I thought that it would be smooth sailing from there but it turned back on, I thought it might just be a glitch or something or maybe the mechanic reset it wrong somehow because everything ran and sounded the same with no change in performance or anything, so I reset the code.
I just replaced my 4 year old spark plugs with NGK TR55 V-Powers as I am trying to get my MPG and performance back, I have slowly gone from about 17 or 18 MPG down to 12.5 MPG, really bad, even for the 30 degree winter mornings, with short stop and go commutes daily.
After driving the car around with the new spark plugs in everything sounded alright, I drove it for about 5 minutes checked under the hood and all was well except I heard a slight "ticking" sound, almost like knocking but not exactly. It wasn't too loud and everything else checked out so I thought nothing of it.
I then hopped on the freeway and opened it up to a 75 MPH cruise, it ran fine, then as I approached my exit and went back into the city my check engine light P0420 code came back on. I have heard that sometimes the cars computer wont run tests unless its at a certain speed for a minute or longer, and this was the first time in a while being on the freeway at that speed for a while, so that may be why its coming on now.
Just wanted to know your thoughts over here, will I need to replace the O2 sensor? Is it possible my terrible MPG is due to a bad O2 sensor? Also, I made sure all spark plugs were gapped and installed correctly, but is it possible that I may have caused a connection to come loose or bumped something while changing the plugs causing the code to come on?
Also, just a side note I've got the problem where the D.I.C. displays low oil level at startup every time even though it is full of oil and has been kept up on oil changed, will I need a new oil level sensor on the crankcase? Estimated cost?
Thanks in advanced for the help, you guys are always helpful here.
