5.5" and smaller (with the right backing plate of course) is all that should be used on your 7424, it just doesn't have the power to spin a 6" pad and do good correction.
I would like to introduce you to Menzerna polishes -
http://www.autogeek.net/menzerna-of-germany.html They are a little pricey, but I tell you right now they are absolutely worth every penny!
My go to method is...
1 - 5.5" Orange Lake Country CCS pad, Menzerna Super Intensive Polish SI-1500
2 - 5.5" White Lake Country CCS pad, Menzerna Super Finish Nano SF-4000
You will want to have several of each pads for each step, I like to use about four pads per step or wash the pad every other panel. A clean pad cuts quicker and leaves a nicer finish.
3 - Wash with a good soap or an IPA wipedown to remove polishing oils
4 - Dry thoroughly
5 - Wax or seal with whatever I want to use
I don't use any pad lube or pad primer or anything like that, just a waste of money in my opinion. If you are worried at all, just give it a very light mist of water from a spray bottle, but even that would only be necessary on the very first pass with a dry clean pad without any polishing residue on it. After that first spot it is no longer necessary.
Wiping down with water alone and microfiber towels will do nothing to remove polishing oils.
Both the PC 7424XP and that Klutch polisher are variable speed units, what speed were you using with them? The 7424 will basically need the highest speed setting to achieve any good correction and the Klutch would need approximately 3/4 or a little more speed. The lowest setting on either polisher will basically do nothing for you, and it sounds like at least the Klutch was set to the lowest speed setting if you could easily stop it by hand. With the 7424 you want to only apply enough pressure to maybe compress the pad half way, but if the pad stops rotating then you are pressing too hard and need to let off some. For the Klutch, apply light to medium pressure, but never a lot, you want the pad to spin and be completely flat on the paint, constant movement, but never really fast.
If with either polisher, while using it, the pad was easy to stop or was stopping then there was really no correction achieved, just filling in the swirls. If that is the case then your car is probably mostly free of any buffer trails and holograms as the polisher didn't have the speed / power necessary to cause them.
yourgrandma wrote:
Pretty much going to echo what ryan said. Ive read that when it comes to "jeweling"(that final ridiculously fine polishing that justifies a $5000 detail, a rotory will finish out better. Thats beside the point....
Exactly, and even then you still have to have a lot of skill and a good amount of practice to really get the jeweling technique down, that involves a very very soft pad with absolutely no cut, a very fine finishing polish with almost no cut, high speed on the polisher and very little pressure.
