Driver side window controls
- samples08
- Posts like an L36
- Year and Trim: 2002 SSEi
88,000k - Location: Piedmont South Carolina
CAn anyone tell me if there is a fuse or relay for the driver side door lock and window controls i think i may have blew it if there is one
Member #3848
- crash93ssei
- Retired Moderator
- Year and Trim: 2002 SE
Re: Driver side window controls
Window and door lock switches not working from the drivers door?
Do the window switches work on the other doors?
If so, you most likely have a bad main window switch module, just fixed mine myself a week ago.
- samples08
- Posts like an L36
Well full story.....(Stupidity included)
I accedently left my driver door wide open and walked back into my house, Well all of a sudden the skies opened up and boom all over my driver controls, they worked for like a day after but seem to have shorted out of coarse, but today i used a wire brush and some rubbing achol (< So spelled wrongly) and i got some fuctionalilty back out of it so should i give that another go to try to get a full recovery, does anyone else have any nefty cleaning tips?
Member #3848
- crash93ssei
- Retired Moderator
Might as well try it, worst comes to worst you will have to buy a new switch anyways, so not really out anything but time and effort if it don't work.
I would try something less aggressive then a wire brush though.
- samples08
- Posts like an L36
Recomendations (much apperciated)
Member #3848
- crash93ssei
- Retired Moderator
I would try rubbing alcohol first with a qtip, then move up in aggressiveness from there... honestly not sure where to go from there though, I would think that much more aggressive would maybe ruin the contacts on the circuit board (if they aren't already ruined anyways)
- Archon
A pencil, and then an ink eraser is a nice step up from there.
jdwiley
- LE Member
- Year and Trim: 2003 Pontiac Bonneville SE
I have the same or similar problem. When you say "Main Window Switch Module" are you referring to the actual panel of window switches on the driver door? The reason I ask is because my lock/unlock switch doesn't work either on the driver door and it is a separate switch assembly. All other doors work fine independently.
-Update-
I replaced the driver door switch panel, fixed!
-Update-
