Hearter problems.
Ashley.Garrison2012
Year and Trim: 1998 Pontiac Bonnville SE.
Hearter problems.
Post by Ashley.Garrison2012 »
I have a 98 bonneville. When i turn my car on and turn up the heat sometimes it doesnt work. Sometimes it will blow out cold air not hot. Sometimes it wont do nothing at ( wont blow nothing out). my boss changed thermaste like couple days ago and it did it 2 times this week again. I cant be the hearter core i think. So must be a electricol thing then. I dont know so i choose to go on here and see.
[IMG]http://i1068.photobucket.com/albums/u453/Ashley_GarrisonC1/100_0236_zps3fb98e94.jpg[/IMG]
Ashley Garrison Carity
repinS
Moderator
Moderator
Year and Trim: 09 G8 GT
Re: Hearter problems.
Post by repinS »
Moved to 1992-1999.
Ashley.Garrison2012
What do you mean
repinS
Moderator
Moderator
Post by repinS »
You posted in the Lounge - mechanical problems should be posted in the area pertaining to the year of your car, in this case, 1992-1999: http://www.pontiacbonnevilleclub.com/forum/1992/
Ashley.Garrison2012
Thanks. Sorry. Didnt know.
nbro3546
Year and Trim: 1997 Pontiac Bonneville SSEI
Post by nbro3546 »
Check the little elbow hose that goes from the blower motor to the firewall. Mine fell off and I had kinda the same problem
Ashley.Garrison2012
How do you do that.
Ashley.Garrison2012
Throught 11/9-12/12 I have no heat. Mainly today 11/12/12 is very cold out and no heat to work. Ugh.
motopsyco
Year and Trim: 1992 SE
Post by motopsyco »
did you check for any relays for it, or it could be the switch at the blower motor itself
bobtaz13
Year and Trim: 2001 SSEi
1991 SE
Post by bobtaz13 »
Even with the fan out the car will heat up when going down the road. I did this most of last year.
The issue is what would stop hot air from getting in the car. Air mix valve? Pluged heater core?
2001 SSEi | Galaxy Silver | GenV supercharger P&P | Intense 3.2 MPS | Intense FWI 4"| Custom PCM | TOG Ceramic headers | Magnaflow 3" cat | 180° stat | Aeroforce scan gauge | PRJ plug wires | PRJ fuel rails | Silicone vacuum lines| AP103 plugs | 3.2 MPS | 42.5# injectors | Intense 1x cam kit | YT 1.8 Rockers | 105# springs | Meziere HD pump | N* Tb | 185mm MAF | 2" Phenolic Intercooler | Oil pressure kit | L32 short block | 5% overdrive SFI Balancer | L67 heads custom ported | EBC USR Rotors | EBC Red stuff pads | Custom HID Fog lights, with HI-beam over ride | Polyurethane motor mount | Energy Suspension end links | GXP Shocks/Struts | Custom Drop springs Front, Rear FE5 Springs | GXP Strut tower Brace | GP GXP 18x8 Rims | Polished Exhaust tips | Triple Edge High Performance Street/Strip 4T65E-HD |
