Hey guys, sorry to bring this up again. After doing a weeks worth of search button, I have tried all types of things to fix this. I am getting p0401 (for those that don't no or remember, it's egr flow recirculation) I clear it and it will come back. My car info is in my signature. I have tried pulling the egr valve and cleaning it. Also pulled the egr tube cleaned that as well. Next I checked and double checked all the vacuum line I just replaced . I do have one concern the T on the top of fpr might be to small for the right amount of air to travel through. (should that matter?) : after wearing out the search button I find that it could be many things I. E map sensor or even o2 sensor. There has to be something else I can try before I go buy un needed sensors. I would like to thank you guys for any help given. I have talked with our local Bonneville grave yard hustler he has to the sensor I need, I'm not sure if it's time to start buying them.
Im noticing that when i reset the code and driving it will only through a cel when im costing to a stop
Sorry about the poor grammar.
DDM tuning HID 6000k hi/lows and fogz
FWI, 180*tstate / 18 inch enkie wraped with potenza run flats , danturs tuned pcm,
Home made motor mount / autolite 605plugs/beldin performance wires. Hogan 3 inch dp w/ magnaflow hiflo cat, zzp plot and 3.4 smoothflow MpS, trans go shift kit, 10 inch gtablet mounted running torque app.
sorry i guess that would help! 215719 miles . i have never replaced the egr there was a rebuild done im not sure if they replaced it that was before i got the car.
and thanks for the reply .. very kind
I ordered one from harofreak. I I hope that will work. Although the car runs great.
Just a quick update I took off the egr tube again just to be sure there was no hair line crack. I the tube looks like new. I pulled all the vacuum off and put air pressure through it not a leak, I am very concerned that the vacuum line I used is not the same Id as the stock one. I hope that's not a problem. I have drove the car for one whole day with no cel. I will be taking a 50 mile trip today I will post back when I'm home tonight. I did buy a new used egr from haro. I will hope that s the issue. He said we could work out something if it's not the issue. I have a good Sunday guys
I have got the egr from harofreak and put close to 100 miles . i was hoping this fixed it . Not the case cel has come on a two times now . not like it did every cost to stop but maybe every other cycle cosing to a stop . ..
I still am getting the same code. I have it down to almost science. If I don't get into boost I never get the cel. Any if I get above 5lbs boost I will get the light next time I cost to a stop. I m thanking the vaccum I have put on might be leaking under boost. Anyone have ideas?
New vacumm harness fixed the damage. 44.00 shipped.. Thanks harofreak for egr.
