Anybody know where I can find stainless steel brake bleeder valves? All the speed-bleeder's I've found thus far only have stainless internals with coated valves (don't care if they are speed bleeders or not). And I'm not sure I trust brass to not break either. This will be for the rear brakes first; had the most difficulty getting them to loosen without breaking them. I already have Ni-Cu tubing for the s-bend on the rear drums, and protected the steel lines that are everywhere else. The hoses are protected by plastic wire-guide.
I'm going to look for some stainless bolts and nuts for the sway bar end links as well.
Stainless steel wire ties work great for rebuilding the C/V axles, we'll see if they last (they have a cammed slot that allows one way travel only). Has anybody seen/know how they make the C/V axle boots? It must take a special mold, for the plastic ones, I could see the rubber ones getting peeled out of a mold. I've been having issues with the one inner boot since I 'fixed' the axle I got from the junkyard, problem being that the plastic has stretched and no longer properly fits and seals on the rubber seal on the tripot housing. I had to tear the axle down to fix the outer rubber boot (tore in the accident), and have tried to seal the gap with the polyurethane adhesive. I'll know if it bonded properly on the weekend (if it didn't I have a temporary fix that involves cutting the boot). Problem is I can't find replacement boots anymore (universals are all junk, nothing fits the HD axle properly). If the PU doesn't work, I'm going to make them using the same technique that I tried with the sub-frame bushings. But the mold will be a 6-piece assembly
Sounds like fun. I was just thinking if this weren't such a messy process I could actually post a how-to.
