2000 SSEi, battery dropped thru floor of back seat
Djkthegame
1987 Bonneville LE
Post by Djkthegame »
has this ever happened to anyone else before, it rusted thru from the inside out probably been rusting away for a while. This past weekend i saw what appeared to be some wedged under my car upon closer inspection if was the rotted piece of what was left of the floor with the battery hanging halfway out.
"CERTIFIED BONNIEHOLIC"
B I-1999 Bonneville SE -My First Bonnie- gone forever
B II-2000 Bonneville SSEi (black) 7/3/09 ZZpcm 1.0, Thrasher Cold Air Intake, Magnaflow hi-flow cat, 180 thermostat, Autolite 104's, solid hockey puck front mount, Intense 3.4 MPS. (OCT 2010 COTM Nominee)
B III-1987 Bonneville LE (burgundy) 7/22/10 -- Gone to Heaven
B IV-1991 Bonneville LE (black) 12/6/12 Parts Car -- Gone!
B V-1998 Bonneville SE (green) 9/11/13 -- 270,000+ and going strong! -- gone 287k+
B VI-1989 Bonneville SSE(gray)9/23/15
Re: 2000 SSEi, battery dropped thru floor of back seat
Sounds like you had a leaky battery for a while. You'll have to get a piece patched in, either welded or riveted...
Djkthegame
1987 Bonneville LE
hey ed haven't seen u in a while. i didnt see any signs of the battery leaking since i have had the car and other than the rust stains from the floor the battery looked clean... i have had her for 3 years now, this caught me by surprise
Yeah, I've never heard of this happening before, lol. Haro's on vacation now, but I'd see if he could cut that patch out of a good car that he scraps to get patched in.
Djkthegame
1987 Bonneville LE
i didnt know he was on vac, i pm'ed him earlier about the RF outside door handle
Yeah He and Shannon are in Vegas. Not sure when they're getting back though...
gweg_b
Year and Trim: 95 LeSabre Custom
01 Bonneville SSEi
09 G8 GT
Post by gweg_b »
Well, I might be the second. Mine's working its way through. I'm guessing either a battery, or water, leaked with the previous owner. When I got the car, and first checked the battery (which that one wasn't leaking), there was a small hole under the battery. Now, it's about the size of a business card. I'm sure the water leaks I've had in the car have contributed to it.
So now I'm trying to come up with a method to fix it before I lose by battery on the interstate. I don't own a welder, nor can I weld, so I have a nice conundrum on my hands.
- Greg | -- Project Prasinos -- |
1995 LeSabre Custom: 312K Miles | Custom K&N CAI | Edelbrock SDT Muffler | Camaro Tips | 180 T-stat | LED Interior
& Exterior | 20% Tint | PA Grill & Portholes | Limited Trim | GTP Rims | Ported LIM | Plus Many More Mods | Restoration Thread
2001 Bonneville SSEi: 225K Miles | Instense FWI | Intense MPS (3.4") | 180 T-stat | ZZP Plog | Ported Rear Manifold |
ZZP 3" Downpipe | Magnaflow Cat | Retrofitted HIDs | GenV M90 | GXP Brake Upgrade | 35% Tint | Plus Many More Mods |
2005 Bonneville GXP: 101K Miles | Custom FWI
2009 G8 GT: 89K Miles | 35% Tint | Roto-Fab CAI | SOLO Mach Exhaust | BMR Tunnel Brace | BMR Sub Frames | BMR STB |
Kooks Headers | QTP Electric Cutouts | BMR Sway Bars | Elite Engineering Catch Can | Innovative Dual Wideband Kit
1984 Caprice Classic Wagon: 86K Miles | Restoration Project
sethjamesrimrodt
Year and Trim: 2004 GXP
Post by sethjamesrimrodt »
Stop the rust(cut it out) then try your hand at fiberglassing, who cares what it looks like. If you wanted to try fiberglassing it would be a good place.
Seth
swampthing
Post by swampthing »
I had this happen to my car years ago. I cleaned up the rust and cut a piece of sheet metal a bit larger then the hole and jb welded it in place. 4+ years with no issues. The battery i had then wasnt leaking either my guess was a previous battery leaked and was never properly cleaned up
Current fleet:
gweg_b
01 Bonneville SSEi
09 G8 GT
Post by gweg_b »
Yeah, the sheet metal with JB weld sounds like the route to go.
It's not like it's in a place where the looks matter.
I'd use some rivets as well, and some seam-sealer. That way it has a mechanical connection to the surrounding metal.
Djkthegame
1987 Bonneville LE
i think im gonna get a cutout from a jy car and have my body shop guy put it in you have to imagine my hole is bigger than the battery itself. theres probably gonna b a nice size cutout around the area coming out too. for now i got it held from underneath with a shelf bracket drilled in to the bottow of the pass side floor pan and a few heavy rubber bunge cords and a well placed length of wood.
xcbullet
Year and Trim: 2000 SE, transg kit & B&M trans cooler
Post by xcbullet »
I think the vapers are anough to cause rust I had a small hole in mine I had to tigar hair. Then I put plastic over repaired area to keep it from getting the acid on it again. I like to fill all my batterys once a summer is how I noticed mine. Dry cell battery would be nice for these body type cars but they cost so much.
Bonneville92V688
Year and Trim: ‘12 Jeep Grand Cherokee Overland Summit
Post by Bonneville92V688 »
Hmm, must be common enough to warrant a TSB.
Floor Pan Corrosion Perforation in Battery Compartment (Install Repair Kit) #05-08-61-002 - (Jan 11, 2005)
2000-2005 Buick LeSabre
2000-2005 Cadillac DeVille
2000-2003 Oldsmobile Aurora
2000-2005 Pontiac Bonneville
Condition
Some customers may comment on corrosion (rust) in the floor pan in the area where the battery is located.
Cause
This condition may be caused by a weeping of acid from the battery or from a battery vent tube that has become dislodged.
Correction
Repair the damaged area using the parts and information contained in the floor pan repair panel kit.. Also, clean any area of the floor pan where acid may have been present with a solution of baking soda and water. Rinse and dry the area thoroughly.
Parts Information
The floor pan repair panel kit contains a replacement section of the floor pan, a battery hold down and instructions. The adhesive needs to be ordered at the time of the repair.
Part Number
Description
88948594
Panel Kit-Floor Pan Repair
12378567 (U.S.)
88901675 (Canada)
GM Metal Bonding Adhesive
Parts are currently available from GMSPO.
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
S5230
Replace Floor Pan
2.6 hrs
Add:
Refinish/Clearcoat
0.7 hr
Add:
Material Codes
GM
Add:
Paint Mix Time
0.3 hr
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
1996 Thunderbird LX - 3.8
Speedin Demon77
Post by Speedin Demon77 »
I doubt it was acid. I've had and inch of water back there several times. I think it was the drain tubes from the sunroof leaking or maybe a crazy trunk leak? Make sure your drain hole doesn't get plugged too.
