How to remove a broken off bolt; weld a blob on it, use a pipe wrench, and viola'! I have a video of this process as well (for later)
And finally, the mystery question of the day, the previously mentioned wire harness that I need to identify:
I want to say this is for the horn on that side.MattStrike wrote:A few more questions while I'm thinking about it; The passenger side wire harness for the headlight, side marker, and fog lamp has another connector on it, IIRC it's a 2 pin or a 3 pin connector. I can't seem to find what it connects to, but that harness goes out the fenderwell, under the battery tray and where it splits for the lights is where this additional connector is at. The drivers side doesn't have this connector.
Look up some videos on plastic welding. It's more or less using a soldering iron with with right temperature and a flat tip to bond parts back together again with extra material.MattStrike wrote:Also, does anybody know how to fix cracks, splits, and other scars on the plastic fenders and bumper covers? The SSEi has a few fender cracks and the rear bumper cover was also cracked. The SE has the mounts for the side markers broke out entirely.
Washer fluid is on the drivers side. I also thought it might be the coolant level sensor?Zeik75 wrote:what about the washer fluid pump for the extra wire?
James May wrote:Hello.
