Help Please
lilpon
Year and Trim: 1992 Pontiac Bonneville SSEI
Help Please
Post by lilpon »
:helpsmilie:
where can i get some of theses parts and were are some of these part located on the car i have a 1992 pontiac bonnieville SSei 168xxx miles on it and theses are the codes that i got from the car.....
21-Throttle Position Sensor Circuit ( Signal Voltage High )
31 - PRNDL Switch Circuit
36 - Transaxle Shift Control Problem
Personal Automotive Security System ( PASS Key ) Fuel Enable Circuit
:helpsmilie: help with this problem
nickburgundy
Year and Trim: 2002 bonneville ssei
Re: Help Please
Post by nickburgundy »
just replace the tps, it is on the tb. cheap and easy fix.
prnld?
2002 bonneville ssei. sd headers, hf cat, fwi, gen v, n*, lq4, egr evap delete, intense tune
[IMG]http://i1063.photobucket.com/albums/t503/nickreck/02bonnevillessei003.jpg[/IMG]
RogueSSEi
Year and Trim: 98 Pontiac Bonneville SSEi
Re: Help Please
Post by RogueSSEi »
nickburgundy wrote: prnld?
Park
Reverse
Neutral
Drive
Low...... Switch circuit
lilpon
Re: Help Please
Post by lilpon »
were is that located at on the car and what is the part called so i can go buy it.
