Fuel Line Connector Elbow Leak
llllcdllll
Post by llllcdllll »
I have a fuel leak coming from the fuel line connector elbow on the fuel rail. After doing some research in these blogs, I've noticed the O-Rings go bad in the elbow. Does anyone know if the size of the elbow is 5/16x5/16? (Part Number: 800-081.5)?? I measured the end that connects to the hose and it's about 8mm (5/16) Thanks in advance guys.
llllcdllll
Re: Fuel Line Connector Elbow Leak
Anyone?
01bonneSC
Year and Trim: 05 Chevy 'Hoe
89 SkiDoo
Post by 01bonneSC »
Should be able to get them at the parts store. Make sure they are rated for use with gasoline, def do not want those deteriorating on a hot engine.
llllcdllll
I checked autozone and o'reilly. Neither had the correct size. I'm going to try the dealer tomorrow but I bet they will try and sell me the whole fuel line =/
01bonneSC
89 SkiDoo
Post by 01bonneSC »
Did you ask for the o ring to the fuel line or just ask for the size that you think it is?
00poncho
Year and Trim: 2000 SE
Post by 00poncho »
i actually had the same problem i got the FORD fuel line repair kit basically it is a new line that you splice in the exsisting line
follow the instructions and it is easy.
DORMAN Part #800059 Nylon Fuel Repair Line - $11 on RockAuto.com
llllcdllll
Thanks guys for your help. I think I found the connector elbow at advance auto (dorman 800-125) they had to order it so if it's not the right one i'll go with rock auto's as harofreak mentioned.
