I mean I can always peal the stuff off, so no bent 5's will be harmed in the making of this project.
Plastidipping rims.
- nos4blood70
Plastidipping rims.
So I've been tossing around the idea of plastidipping my bent 5's for the winter. What say you guys? Yea or nay?
keir
- SSEi Member
- Year and Trim: 2000 ssei
Re: Plastidipping rims.
Never heard of the process,what's it entail?
Black 91 SSE-Where it all started....
Red 95 Grand Prix SE-Gone but not forgotten....
Grey 00 SSEI -The current daily driver.
Dark Grey 2011 Dodge Charger-The new flagship.
RogueSSEi
- Year and Trim: 98 Pontiac Bonneville SSEi
Try one and see if you like. If you don't pull it off, mentioning of wheels I've thought about doing the 20's plastidipped.
Keir: it's basically a thin plastic, but durable coating that you can spray from paint can, aerosol etc. a guy on YouTube plastidipped his entire Audi.
ga93sle
- Year and Trim: 06 Grand Prix LS4
I guess if you want black 5 spokes for winter wheels, go for it! lol Like you said, you can always just pull it back off...
- haro1225
- Posts like a Northstar
- Year and Trim: 2004 GTO
Give it a try, I just did mine about a week ago. Only took one can. Worst case if you don't like them, you're only out $7.
-Ryan
2013 Audi Allroad Quattro
yourgrandma wrote:Hi.
01bonneSC
A lot of hand tools have their handles dipped with plastidipkeir wrote:Never heard of the process,what's it entail?
- RJolly87
My initial concern was the longevity of the product. Also, as it ages, would it start pulling away, giving a way for crap to accumulate behind it? Not counting what wheel weights would do to it.
~Randall~
01bonneSC
On any aluminum or chrome rim,IMO, there should NEVER be weights on the outside lip. Looks tackey.RJolly87 wrote:My initial concern was the longevity of the product. Also, as it ages, would it start pulling away, giving a way for crap to accumulate behind it? Not counting what wheel weights would do to it.
I'm all for static balancing or if you don't like static balancing, stickey weights just inside of the outter part of the rim.
- theax40
- GXP Member
- Year and Trim: '03 SSEi
I did mine a couple months ago, it would make a great protective layer in the winter. However, clean your rims ridiculously well with some degreaser. The 20 spokes have a sort of divot that runs along inside the edge of the rim and the dip has separated and lifted up off those parts. It's pretty durable but won't stick well for long if your rims aren't super clean. Brake dust will turn the front rims a weird brick-like red color, so ceramic pads would be a good idea.
To the guy who only used on can: was that for each wheel or all of them? You gotta put on more than a few coats, one can for four wheels won't be enough.
- nos4blood70
I heard that 2 cans should suffice for rims like sawblades since they don't have too many nooks and crannies.
- haro1225
I managed three coats on all the wheels with one can.theax40 wrote: To the guy who only used on can: was that for each wheel or all of them? You gotta put on more than a few coats, one can for four wheels won't be enough.
-Ryan
01bonneSC
Ohhhhh so it's plasti-spraying, not dipping.
- theax40
- GXP Member
It's hard to tell if the 20 spokes have more surface area than bent 5's. Sure, there's a lot more spokes but they're much smaller. But you can't forget all the surfaces on the side of each spoke that need coverage too. So 20 spokes might need more cans.
I removed my rims, did 3 coats on the back face of each spoke (so the dip on the front sticks better around the sharp corners to the back) and the inside of the entire rim. The entire wheel is dipped black, inside and out. Full can for each wheel.
I wouldn't skimp and go lightly with the 'Dip, more layers=better. It's super cheap and if you end up with extra, you can dip other, non-car related things. I Plasti-Dipped my iPhone sync cable.
