Suspension
ijreed
Year and Trim: 1996 Pontiac Bonneville SSEI
Suspension
Post by ijreed »
I was wondering what suspension i could get to be on par if not better than the original struts on my 1996 pontiac bonneville ssei.
MattStrike
Year and Trim: '99 Montana
'04 Dirtymax
'97 Camaro
'92 Trofeo
Re: Suspension
Post by MattStrike »
My opinion: OEM or KYB GR-2
Boost addict
The Fleet:
'97 Camaro - Top swap
'05 STS - V8, AWD, her DD
'92 Trofeo - Fair weather DD
'99 Montana - top swap 3800
Current project:
Something cool, trust me.
Upcoming projects:
'92 Bonneville SSE
'87 LeSabre T-type
'67 LeSabre
Gone to greener pastures:
'97 LeSabre - Top swap
RIP:
'86 LeSabre - pictures
'93 SE - L67
95naSTA
Re: Suspension
Post by 95naSTA »
Hands down Monro-matic plus shocks. Don, jr's3800, pointed me in this direction after not being impressed with the GR-2s.
I've only run them in the rears though since I went a different/hybrid direction with the fronts.
ijreed
Re: Suspension
Post by ijreed »
What about in the front? I have the Monroe quick struts in the front and the back of my car and its kind of bouncy. Also what is the price range on those if you don't mind me asking?
95naSTA
Re: Suspension
Post by 95naSTA »
I went with a KYB-AGX front strut for a W-body (Grand Prix/Regal/etc.) for the front because GR-2s couldn't keep up with my old 2" drop. It's not a direct swap and it gets pricey. The link in my sig has more info.
Don has suggested the Monro-matic plus struts for front and rear as an OEM replacement. Rock Auto has them if you want to look up the price.
ijreed
Re: Suspension
Post by ijreed »
Will the struts you named stiffen the ride up quite a bit versus the quick struts? It bounces everywhere. Also is there any upgrades i can do for good cornering.
MattStrike
'04 Dirtymax
'97 Camaro
'92 Trofeo
Re: Suspension
I thought all SSEi models had the firmest suspension options already, so going stiffer will be more difficult and probably require some custom work. But bigger sway bars, larger diameter rims, wider tires, strut tower braces and other structural braces will all help cornering. As well, replacing suspension bushings, strut mounts, etc...
But, I only every had OEM F41, FE1, FE2, Monroe Gasmatic, and KYB struts to compare side-by-side and haven't played with anything else (was happy that a '86 LeSabre could keep to the corners like my brothers' W-body).
Boost addict
The Fleet:
Current project:
Upcoming projects:
'92 Bonneville SSE
'87 LeSabre T-type
'67 LeSabre
RIP:
'93 SE - L67
ijreed
Re: Suspension
Post by ijreed »
I don't have the factory struts anymore. I have the Monroe quits struts on the front and rear. I was asking will the struts 95naSTA named be stiffer then the ones I have.
95naSTA
Re: Suspension
Post by 95naSTA »
ijreed wrote:Will the struts you named stiffen the ride up quite a bit versus the quick struts? It bounces everywhere.
Yes, they should.
ijreed wrote:Also is there any upgrades i can do for good cornering.
Addco makes sway bars for our cars: http://www.swaybars.com/searchresults.a ... LE%20(FWD)
Those year ranges on their site are a little wonky though..
ijreed
Re: Suspension
Post by ijreed »
Would polyurethane end links in the rear help with understeer.
