Anything i should know before i order my FWI??
PronksBonne
Year and Trim: 2004 Bonneville SLE
Post by PronksBonne »
Hey all within the next few days i plan on buying the fwi from intense. Is there anything i need to know before i buy it. Maybe possible problems ill have while installing. Or if i ever need to go to have something fixed at a shop, will i have to put my stock air box back on?
All Maintenance will be done over the next few months into summer. My next step is to replace the upper intake manifold and LIM gaskets.
As far as other performance upgrades up next will be high flow cat, down pipe, and pcm. Possibly aero turbine exhaust, i love the sound already, but would like to see what these sound like. I know i probably wont be getting any better flow from these than stock, just want to see the sound difference.
Any information at all is greatly appreciated..
Re: Anything i should know before i order my FWI??
You will have to drill into the subframe to mount the PCM tray.
deano55
Year and Trim: 2003 Bonneville SSEI
Post by deano55 »
nos4blood70 wrote:You will have to drill into the subframe to mount the PCM tray.
drill the subframe??
01bonneSC
Year and Trim: 05 Chevy 'Hoe
89 SkiDoo
Post by 01bonneSC »
It's just the body. The ledge where the pcm sits normally.
01bonneSC wrote:It's just the body. The ledge where the pcm sits normally.
Whoopsies! Yeah, that's what I meant. Sorry for the confusion!
redzmonte
Year and Trim: 2000 SSEI
Post by redzmonte »
couple self tapping screws work very well..
S
Shane "RedZMonte"
2004 Z16 Z06: Virgin
PronksBonne
Will the intake throw a code??
01bonneSC
89 SkiDoo
Post by 01bonneSC »
PronksBonne wrote:Will the intake throw a code??
Nope.
yourgrandma
Year and Trim: '02 SSEi
Post by yourgrandma »
Make sure you've got healthy body clips on your bumper cover. My filter always tries to push the bottom tray out of the bumper cover.
vogie01
Post by vogie01 »
yourgrandma wrote:Make sure you've got healthy body clips on your bumper cover. My filter always tries to push the bottom tray out of the bumper cover.
Mine did when someone bumped my front end very lightly in a parking lot.
I lost mine on the highway after someone stood on my bumper on the grille ledges.
PronksBonne
anyone have any pictures of what everything should look like step by step? the instructions they sent me arent helping me too much. For example, mounting the pcm tray, replacing the old sensor spot with new.. the sensor seems to be hard to get out of the old tubing. Any help would be great, ive done searches and havent found anything
To get the sensor out you just gotta wiggle and wiggle. I ended up just stepping on the old tubing to make it open up enough to get the sensor out.
PronksBonne
Thanks!! Ended up getting it out!! It sounds amazing!! Cant wait to continue modding!!!
