Whats the best performance upgrade one can do to a N/A 3800?
BumpinBonneville17
Year and Trim: 1996 Pontiac Bonneville SE
Re: Whats the best performance upgrade one can do to a N/A 3800?
Post by BumpinBonneville17 »
willwren wrote:Many L36's here have used the 3.5" FWI and are very happy with it. Get someone to compare 3" to 3.5" on the same car to settle that.
My opinion? The 3" is a proven good size for the L27, and the L36 moves more air (because it revs and shifts at higher rpm's) and revs quicker (needs to develop velocity quicker) simply because it has lighter rotating internals.
You'll be better off with a gutted airbox than an ebay intake. The airbox won't pull hot air from the engine bay.
Are there any forums showing how to properly gut an airbox for a 96 bonny? :bhuh:
Thanks,
Bumpin'
1996 Bonneville SE
-20,000 miles on Brand New motor, 140,000 on car, Black Leather,
-Clear Corner lights, Gutted Airbox, Xenon High/low beams & Fog bulbs (all of em)
-2 12" Volfenhag Aluminum cone 500 watts RMS a piece DVC subs, 1000 Watt RMS Ultra Linear Amplifier, 3.0 Farad Capacitor, cooling fan for the amp, Kenwood Deck & 6x9's
Post by gonzo4191 »
i don't feel like searching, i can help you out with the gutting though....
95naSTA
Post by 95naSTA »
Barry wrote:If so, what was the purpose of GM going from the 3" to the 3.5" throttle body inlet?
To make up for the cross sectional area that is lost from the MAF sensor.
willwren
Post by willwren »
That theory doesn't hold water. The MAF posts are essentially the same between the 3" inlet L27 TB and the 3.5" L36 TB inlet. Same basic cross-sectional area.
The L36 TB inlet OUTER diameter is 3.5" instead of the L27 3.0" because the L36 throttle plate is a larger diameter to support more flow (at the higher rpm's the L27 never sees with it's lower shift points).
In simpler terms:
GM 3800's went from a 3" TB OUTER outlet diameter to a 3.5" in 1995 with the debut of the L36 because the throttle plate changed from the 58mm L27 size to the 65mm L36 size.
That's about 2.25" in diameter for the L27 to 2.5" on the L36.
BumpinBonneville17
Hey I Installed the cheap ebay intake and I see exactly what you mean by useless. The filter itself got almost too hot to touch after only a short drive. It was like 92 degrees Fahrenheit outside today too so that wasn't helping the situation. I'll probably just throw the stock box back on until I can assemble a good CAI with a box and insulation.
P.S. I looked through almost all your pictures and I couldn't find any of the 96-99 style bonny with the blacked out tail lights? I saw one pic that may have been the corner of one but that was all I could find? :???:
Last edited by BumpinBonneville17 on Wed Jul 16, 2008 1:47 am, edited 1 time in total.
1996 Bonneville SE
willwren
Post by willwren »
Forget even using that filter if you plan on shielding it.
I'll bet you that filter will hold water. Try it. APC brand? Not marked? Give us a link to your auction/seller etc or a pic you have of the intake.
BumpinBonneville17
willwren wrote:Forget even using that filter if you plan on shielding it.
http://cgi.ebay.com/ebaymotors/92-05-Po ... enameZWDVW
Let me know if that link doesn't work.
1996 Bonneville SE
Roadtech195
Year and Trim: 2007 Grand Prix GT
Post by Roadtech195 »
That looks like a cheesy ass spectre filter, they do hold water and they have a loose seal at the base plate. Mr.Wren is very correct about them holding water, I tested one 3 weeks ago from a friends 92 Riviera. I poured water into the filter and it took 18 seconds to drain it and 2 days in 100 degree weather to dry it out.
2007 Grand Prix GT L32
Poly endlinks, swaybar bushings and dogbone bushings. Drop in high flow air filter. Its a start!
2009 Mitsubishi Eclipse GS (project BlackSheep) Bone stock for now, 5 spd and fun as hell! (Gf's Ride)
1996 Pontiac Bonneville SE Gone but not forgotten
1997 Dodge Ram Sport 4x4 5.9L The Beast!
BumpinBonneville17
K definetly ripping that piece out and slapping the stock box back in for now. Ho do you gut a stock airbox?
Thanks,
Bumpin'
1996 Bonneville SE
Post by gonzo4191 »
send pictures of your box looking into it from both sides in a pm, i'll show you want to cut out.
willwren
Post by willwren »
I had my suspicions about those filters when I found DrJay on the old Forum had one when I was in Washington at his place about 5 years ago. On a hunch, we used water to test flow, as we all know how K&N's deal with water (if you've ever cleaned one).
An hour later he had better performance and a different filter. 2 hours after that he had a heatshield. INTENSE hadn't created the FWI at that point.
We also knew alot less at that time about diameters, flow, what works, and what doesn't. Our point here is to make sure that you actually do add the performance you want, rather than lose.
95naSTA
Post by 95naSTA »
willwren wrote:That theory doesn't hold water. The MAF posts are essentially the same between the 3" inlet L27 TB and the 3.5" L36 TB inlet. Same basic cross-sectional area.
In simpler terms:
I don't really see how that disproves my theory.
Yeah, the MAF posts are the same size in both TBs. I doubt it would have been cost effective to change that.
willwren
Post by willwren »
Mike, you stated the MAF cross-sectional area loss was the cause of the 3.5" TB. It's not. It's the throttle plate diameter increase that caused it.
95naSTA
Post by 95naSTA »
willwren wrote:Mike, you stated the MAF cross-sectional area loss was the cause of the 3.5" TB. It's not. It's the throttle plate diameter increase that caused it.
Ahh. Yep I read the OP's question wrong.
You're right.
BumpinBonneville17
hey sorry for the delay. Here are some Mad pics of my stock air box so someone can tell me how to properly gut it. :banana:
headlight side
left side
Engine side
Engine side hole with elbow
Engine side hole without elbow
inside of headlight-side half
stock filter on engine-side half
inside of engine-side half without the filter
Thanks for any suggestions to get MORE POWER!!!! :bband:
Bumpin'
1996 Bonneville SE
Post by gonzo4191 »
here you are.
for the headlightside, cut or yank out along the red dotted line.
for this engine side, cut/yank along the red. you might be able to do sometihng along the green side, but idk if thats the back of the box, you will have to look.
do not touch the side of the box where the elbow to the throttle body connects
Barry
Year and Trim: 1999 SSE
Post by Barry »
You'll see little plastic tabs that hold the baffle in there, along the red dotted line. Just grind or drill them off. The baffles will come right out.
1999 SSE. 112k, Cleared Corners, Mobile 1, Energy Suspension endlinks. Ported and Polished LIM, NGK TR-55 Sparkplugs, 180 drilled Intense stat, Flow matched injectors, Intense FWI, Intense PCM, MagnaFlow Cat.
Post by Jrs3800 »
First remove this piece
This will be the result
Then start cutting the front of the Box Open
Then you'll have to remove this baffle
As you can see here the Tube is attached to the baffle, You'll now see the rear half of the Box is open...
Thats pretty much what you do to Gut the air box.. :twisted:
ptrfair
Year and Trim: 2007 Impala SS
1997 LeSabre Limited
Post by ptrfair »
I did that about March. we also threw in a new exhaust and cat in.
well...the mechanic did the cat. he knew i wanted HP so he found something.
result.... the car has MAD pickup power. :twisted: all i hear with someone else in the car with me "are we taking off for space or something?" :beerchug: I even keep up with my dads 745Li. (its used lol). I mean i have another friend with an SSEi and its no comparison but still one heck of an improvement. you'll like the gutted box idea. quick fix to power.
2007 Impala SS - 30k 5.3L V8
1997 LeSabre Limited - 115k
Gone but never forgotten:
2001 Bonneville SE
1992 Bonneville SE
BumpinBonneville17
Hey I did it and Am going to install it tonight and get that crappy ebay hunk outta there! I am now thinking of wrapping the stock air box in that Reflectix stuff from menards to help with heat. What else could I do? Does any one sell any high flow air filters that fit into the stock box?
Thanks,
Bumpin'
P.S. special thanks for the guys who posted the awesome pics. they made gutting a breeze!!
:banana:
Last edited by BumpinBonneville17 on Mon Jul 21, 2008 11:09 pm, edited 1 time in total.
1996 Bonneville SE
