New tranny?
01ssei
Year and Trim: 2001 Pontiac Bonneville SSEI
New tranny?
Post by 01ssei »
So its got about 135, 000mi and the tranny seems to be whining and shifting pretty hard specially from 1-2 & 2-3. Would a flush and filter change fix this or is a new tranny in need?
Re: New tranny?
The hard shifts are due to the PCS and many mask it by installing a shift kit. A pan drop with a new filter and oil is a good idea and is part of installing the shift kit also.
redzmonte
Year and Trim: 2000 SSEI
Re: New tranny?
Post by redzmonte »
doesnt hurt to drain, replace filter and refill. have seen it help some trans. don't know if the filters get clogged or what but its cheap adn worth a try.... It definatly won't hurt. Don't get a "TRANS FLUSH" just drain the fluid out the pan, change the filter and refill with fresh fluid (5-6qts iirc)
S
Shane "RedZMonte"
2004 Z16 Z06: Virgin
