So I have an idea of where the fuel injector harnesses go, luckily they are labeled by number to the respective cylinders (please correct me if I am wrong). I realize a lot of the harnesses should just fit due to proximity, but I just want to be extra sure before I start trying to force prongs where they shouldn't go. Like I've mentioned before, nothing was labeled when this engine was pulled apart (which is a mistake I would never make again)
Here is a full view of the wiring harness, with my arbitrary and poorly designed divisions :-p
Closeup of the middle
Part A, which extends from the PCM I believe. I've kind of separated each specific plug by letter and number and these are the ones I am not entirely sure of.
Part B
Zoom out of C, with random plug at bottom I forgot to label, we can call it U1
Part C
Part D
Part E
Part F, Again, you can see where U1 bridges C and F
Part G, if you look closely, fuel injector 2 extends on the left from the two G1 and G2, and fuel inject 4 extends from the same root as the single G3
Part H, I am guessing the big one goes to the back right section close to the firewall, but not sure about that vacuum looking piece (H1)
This I am calling part X, these guys are just separate from the big loom altogether.
Anyway, if anyone happens to have notes, pictures, or even remembers where all of these go I would be forever gracious!!
