Component speakers for 01 bonneville
flgator346
Year and Trim: 2001 Bonneville SLE
Post by flgator346 »
I was just wondering and was wanting some opinions... Does anyone know of the best sounding component speakers to put in the front doors??
xrob
Year and Trim: 2002 Bonneville SE STOLEN
2001-05 Bonneville GXPI
Re: Component speakers for 01 bonneville
Post by xrob »
conduct a search through a couple pages...this is a frequent topic?
Polks are awesome for the money. Alpines seem to be popular as well.
sethjamesrimrodt
Year and Trim: 2004 GXP
Post by sethjamesrimrodt »
I have had many alpines, type r's, type x refs, and type x pros. I have also installed polk mm's in a friends car. I like the type x pros the best, but for the money the polk mm's are a very close second.
Seth
flgator346
Thanks for the opinions! I will research them!
You might like this:
http://www.sonicelectronix.com/item_381 ... ckage.html
I kinda wish I did that right from the start.
flgator346
that does look good... Thanks!
BFF_Larry
Year and Trim: 95 bonneville sse
Post by BFF_Larry »
try out ID Ctx's
95 bonny sse WALLED.
-new build in progress-
Iraggi HO alt - 320 amp (added "sense" wire and 5k pot, 15.4v)
2 DC Level 5 18s
Cactus Sounds K12
4 runs of 1/0
14 batts.
Mtx 4244 and (2) kicker ix404
YouTube.com/user/pitchdarkshadow
sandness
Post by sandness »
With components, I'd say your best bet is to go to the shop and play with some. I have some MTX 8000 6.5's that I never would have considered a few years ago until I listened to them.
swampthing
Post by swampthing »
What else have you done to the system? Are you running the factory headunit? If you are using the stock amp i am not sure any component system will perform as well as it should. You should be looking for a component system that has an impedance of 2ohms, most likely infinity will be the best choice. I would try looking at infinity's reference components since they are less powerful then the kappas. But i am still concerned that the bose amp wont run them very well
Current fleet:
DCJREDLINE
Year and Trim: None
Post by DCJREDLINE »
There are alot of good choices out there, all depends on your ears. Some like different things in their speakers.
Personally I like MB Quart, their highs are much more crisp to my ears (enjoyably) most others are too raspy to me.
I also have heard alot of good JL components, MTX, Pioneer, and Alpine are all right up there for me.
2004 Saturn Ion 3 Quad Coupe
