Fixed charger now problems
01ssei
- Year and Trim: 2001 Pontiac Bonneville SSEI
Saturday I replaced my thermostat and I noticed the actuator for the super charger the arm was sticking so I loosened it up with some oil now it works good boosting 7-8psi yesterday I was driving and lated into it a bit and noticed that my charger might be vibrating and my check rhine light started flashing it stopped wen I got off the throttle... My scanner is at work any suggestions
- crash93ssei
- Retired Moderator
- Year and Trim: 2002 SE
Re: Fixed charger now problems
Your supercharger is very unlikely to be vibrating enough for you to feel it unless it is about ready to have a catastrophic failure and you would feel that whether or not you were getting on it.
Sounds like it could have been some missfires, probably a bad plug or wire. When was the last time the plugs and wires were changed?
A flashing CEL means there's a "catalyst damaging condition", generally a misfire, and a misfire will shake the whole car.
Replace your plugs and wires (I HIGHLY recommend NAPA Beldin Wires and Autolite or NGK plugs, NEVER Bosch) and your fuel filter. Then see if the misfire goes away or not.
Ken_W
- Posts like an L27
- Year and Trim: 2000 SSEi
Some fuel injector cleaner might be a good idea also, such as Techron, Gumout, or Seafoam.
bc21
- SSE Member
- Year and Trim: Black 2000 SSEI and Red 2000 SSEI
Ed has some good suggestions the Napa premium Beldin wires are great. I bought a set of these wires today, put them on in an effort to clear up my misfire problem. Cables worked great but it turned out to be a bad coil pack. I reserved them on line through napa.com and got 10% off. total was about $27.
