The new and improved hockey puck mount
sethjamesrimrodt
Year and Trim: 2004 GXP
Post by sethjamesrimrodt »
After I replaced my motor mount with a “solid” hockey puck mount (nothing wrong with that mount I just like a little more give in my drive train) I started work on a semisolid OE style mount. First I cut the bad motor mount so that I could use the top half of the old mount in the construction of my new mount. Image This is what’s inside an OEM mount. Image This is the only piece of the OEM mount I am using.
I then cut a piece of tubing that was 2 ¼ inches long with an ID of 3 inches and an OD of 3 ¾ inches. I also cut three pieces of solid round stock 3 inches in diameter, two of which were ¼ inches long and one that was ½ inches long. Then I drilled a ½ inch hole in the center of the two ¼ inch discs, and in the center of two hockey pucks. Image
I then sanded the out sides of the ¼ inch disks keeping them round so they would easily move inside the 3 inch pipe. Image This is how the mount will sit when it’s completed.
The ½ inch disk is a spacer I used while welding one of the ¼ inch disks to the inside of the 3 inch pipe a ½ inch from the bottom of the pipe. I forgot to take a picture of that part. I then welded a 12mm nut onto the end of a 5 inch long piece if 12 x 1.75 threaded rode. Then I welded the bottom side of the nut onto the last ¼ inch disk through the ½ inch hole, so I ended up with a threaded rode with a 3 inch washer welded to the end of it. I then welded the top of the OEM mount to the top of the 3 inch pipe with one hockey puck inside.
The way I designed this mount the engine and transmission can still move slightly in both directions the push and pull, but the mount will not be able to pull through like an OEM mount. Image I still have to pain the mount and yes it is a little heavier then an OEM mount weighing in at just under 6lbs.
I’m not sure when or if I am going to put this on my own car. Maybe I will right before I get another alignment so when I drop the sub frame I can re align my tires.
Seth
Re: The new and improved hockey puck mount
Nice fab skills!
CMNTMXR57
Post by CMNTMXR57 »
No doubt.
Is it just me, or does that OEM mount "cup" (if you want to call it that), still look flimsy?
Daily Drivers:
2011 Camaro SS
sethjamesrimrodt
CMNTMXR57 wrote:No doubt.
Are you talking about the top part of the mount?
Seth
CMNTMXR57
Post by CMNTMXR57 »
This;
Daily Drivers:
2011 Camaro SS
sethjamesrimrodt
I think it will hold up, its 1/8 inch thick with lots of bends to make it stronger I guess time will only tell.
Seth
iRoll4z
Year and Trim: 2001 ssei bonneville
Post by iRoll4z »
so the gxp bonnevilles have the same motor mount problem?
sethjamesrimrodt
iRoll4z wrote:so the gxp bonnevilles have the same motor mount problem?
Yes they are pretty bad..
Seth
