Look at what i found in the under my car
glenn304bonne97
- Year and Trim: 1997 bonneville se
This was laying up under my car what could it be is it something of the frame or some type of support
[img][/img]
- J Wikoff
- Year and Trim: 1992 SSE
Re: Look at what i found in the under my car
That's an engine subframe bushing. It would be a good idea to replace it before driving the car. Hopefully the bolt that it came off doesn't fight you too much (if it's not already snapped).
EDIT: Look at the points where the structure under the engine mounts to the body.
glenn304bonne97
Is this something thats will cost a lot to fix and where are they located at on the car
[img][/img]
- 95naSTA
- Year and Trim: 95 SLE
If you are able to remove the old bolt or snapped bolt it won't cost much.
There are 6 mounting points from the subframe to the car. The two in the front are the least likely to have issues.
Then there are two, per side behind the front wheels under the car.
This is a picture of the driver side subframe mounting. #3 is what fell off your car and #4 had to deteriorate and fall off before that.
http://www.gmpartseast.com/pontiac/comp ... 2hx69.html
- J Wikoff
My response to seeing that under my car would be "FML", or possibly "Oh balls".
- 95naSTA
I found a washer under my car (#4) maybe 3-4 years ago. The bolt was fine and all the other washers lasted another 2 years until I ripped the front end apart to do a bunch of work.
RogueSSEi
- Year and Trim: 98 Pontiac Bonneville SSEi
I thought it might have been the frog.... just chillen'
glenn304bonne97
So will it be safe to drive it for few days till i get it looked at and whats good price to pay for them bushing
[img][/img]
- bigryan18
- Year and Trim: 1997 Bonneville SE
Check out my post named Nice time to break...
Snow White- DCJREDLINE
- Year and Trim: None
I dont think anyone here would say go ahead and drive it that way. Your whole engine cradle could fall out of the car while driving down the highway. Does that sound like a safe idea?
I say have that thing looked at before risking yours and everyone around you's life.
2004 Saturn Ion 3 Quad Coupe
glenn304bonne97
Okay so i went to the dealership how do i know which color goes on my car or can i get a aftermarket kit online for a good price
[img][/img]
RogueSSEi
Which color?glenn304bonne97 wrote:Okay so i went to the dealership how do i know which color goes on my car or can i get a aftermarket kit online for a good price
Have you checked with ZZP, Intense, or Rockauto for aftermarket/upgraded units?
- 95naSTA
All 92-99 subframe bushing info is very easily found through a search..
If you click the link I posted you'll see what colors go where.
p.s. ZZP/Intense or any 3800 vendor for that matter, does not make kind of bushing upgrade for our cars.
glenn304bonne97
So that still dont tell me what color i need to use for #2 its giving me three colors to choose from???????????
[img][/img]
ChilinMichael
- Posts like a Northstar
- Year and Trim: 2004 Volvo S60
I just dealt with this a few months ago, yes diff. colors for different areas. You better order an entire complete set. You'll see what goes where once you have it in hand. Replace them all, you'll be thankful later.
glenn304bonne97
So i need to buy a complete set see i only need one side done the other side has already been maybe two years ago but the guy i got the car from. ive been tryin to get ahold of the guy to see if he bought the whole set of bushings but he wont call me back. do i really need to buy a whole set i really need to figure out what i need to for the two on bushings on the passenger side.....????
[img][/img]
ChilinMichael
You can buy separate. Just usually people don't replace one or two, not from what I've seen. When one falls apart, the rest are coming shortly after. If you know that he did a few of them, and you know which ones, just replace the remainder (and inspect)
glenn304bonne97
So why does this has to be so hard to figure out what color goes on my car can anybody help me out :(
[img][/img]
- J Wikoff
I'm not familiar with the color differences or what they signify. Do you have any info on the colors, does is mean size, or stiffness...?
glenn304bonne97
THE STIFFNESS IS WHAT IS MEAN BUT I CANT FIND ANYTHING ELSE OUT THEN THAT
[img][/img]
