Recommended oil
bonnie_99
- Year and Trim: 99 SE
Recommended oil
99 Bonneville, non-super charged, 110k miles. What kind of oil do you recommend? Is high mileage or synthetic a good idea or just stick with regular oil?
- SSEiMan01
03 PAU - Location: DeKalb, IL
Re: Recommended oil
Do a search on here, this has been discussed many times before, to not too much of a conclusion. There are a lot of people who run Wal-Mart brand synthetic or conventional and have the same results as people who run Royal Purple. lol Oil filters make the difference, get a good quality one. HM depends on the condition of the motor in my opinion. IIRC that has come up in the past too.
James May wrote:Hello.
- MattStrike
- Year and Trim: '99 Montana
'04 Dirtymax
'97 Camaro
Re: Recommended oil
Use what you prefer, change it when it's dirty, use a good filter, keep on driving
Boost addict
The Fleet:
'97 Camaro - Top swap
'05 STS - V8, AWD, her DD
'92 Trofeo - Fair weather DD
'99 Montana - top swap 3800
Current project:
Something cool, trust me.
Upcoming projects:
'92 Bonneville SSE
'87 LeSabre T-type
'67 LeSabre
Gone to greener pastures:
'97 LeSabre - Top swap
RIP:
'86 LeSabre - pictures
'93 SE - L67
The Fleet:
Current project:
Upcoming projects:
'92 Bonneville SSE
'87 LeSabre T-type
'67 LeSabre
RIP:
'93 SE - L67
- murderedout
- Year and Trim: 1989 bonneville LE flat black paint 133k
Re: Recommended oil
Bob is oil guy google him
Mad Myche
- GXP Member
- Year and Trim: 1999 Bonneville SE
Re: Recommended oil
No one has yet said "Don't use Fram Filters"
Anyways.... I really don't buy into the high-mileage stuff. All of my 305/350s and even the 20R in my celica used normal oil year round and were well into the 250 - 300 range when they were terminated from non-engine causes
~Mad Myche from Around Milwaukee~ wrote:Contrary to what some may think... I have not lost touch with reality, rather; reality cannot keep up with me
deano55
- Posts like an L36
Re: Recommended oil
I have driven our cars to 255k with walmart oil and filters, and they went to the junk yard rusty not broke or sold them with 200k. I'm not a die hard brand oil person because I have seen enough friends use cheaper brands and get great miles on their cars, but changing oil and filters when they or I should. Clean oil is a must. I wouldnt go recycled oil though myself.
LeSabre in Buffalo
- Year and Trim: 2012 Eco
Re: Recommended oil
Nothing wrong with "recycled" motor oil. It's more like re-refined motor oil. I've heard it's actually cleaner than other regular oils since it has to meet higher standards before it can get onto the shelf.deano55 wrote:I have driven our cars to 255k with walmart oil and filters, and they went to the junk yard rusty not broke or sold them with 200k. I'm not a die hard brand oil person because I have seen enough friends use cheaper brands and get great miles on their cars, but changing oil and filters when they or I should. Clean oil is a must. I wouldnt go recycled oil though myself.
These engines really don't care about dino or synthetic. The only reason to go synthetic in these cars is to extend the change time out a bit longer. If you're putting on 2500 miles a month, changing at 7500-10k miles compared to 5000 miles saves a good chunk of time and money over a year. If you're putting on 500 miles a month, then changing at 5000 miles makes a ton of sense.
- nos4blood70
Re: Recommended oil
I've been running recycled motor oil for my last 4 or 5 oil changes. Penny doesn't complain whatsoever.LeSabre in Buffalo wrote:Nothing wrong with "recycled" motor oil. It's more like re-refined motor oil. I've heard it's actually cleaner than other regular oils since it has to meet higher standards before it can get onto the shelf.
deano55
- Posts like an L36
Re: Recommended oil
dont see why it would have higher standards to get on the shelf, maybe a explaination?LeSabre in Buffalo wrote:Nothing wrong with "recycled" motor oil. It's more like re-refined motor oil. I've heard it's actually cleaner than other regular oils since it has to meet higher standards before it can get onto the shelf.deano55 wrote:I have driven our cars to 255k with walmart oil and filters, and they went to the junk yard rusty not broke or sold them with 200k. I'm not a die hard brand oil person because I have seen enough friends use cheaper brands and get great miles on their cars, but changing oil and filters when they or I should. Clean oil is a must. I wouldnt go recycled oil though myself.
1oldman
Re: Recommended oil
Agreed on everything posted:
1) don't use Fram filters: NAPA Gold, Wix, PureOne, AC Delco and many others a fine. Change the filter when you change the oil.
2) Oil, follow the owner's manual. I prefer to use Walmart Synthetic. As long as it's GF5, it'll work great, even conventional oil, as long as it's GF5.
We have almost 285K miles on our '92 and having the valves ground is the only thing done to the engine. It actually runs better after the valves were ground than when it was new.
- BC
- BC
LeSabre in Buffalo
Re: Recommended oil
The re-refiner doesn't know what's in the feedstock, so they have to really filter and refine the oil to make the final product. Also, all sorts of petroleum products such as ATF and gear oil get mixed in with "used motor oil", so they need to filter out all the additives and wear metals in those to get a usable product. Then, they need to further "crack" the filtered oil to get the right grades of oil needed for engine oil. The oil made from the stuff that comes from the ground isn't filtered as thoroughly since it's more uniform to begin with.deano55 wrote:dont see why it would have higher standards to get on the shelf, maybe a explaination?LeSabre in Buffalo wrote:Nothing wrong with "recycled" motor oil. It's more like re-refined motor oil. I've heard it's actually cleaner than other regular oils since it has to meet higher standards before it can get onto the shelf.deano55 wrote:I have driven our cars to 255k with walmart oil and filters, and they went to the junk yard rusty not broke or sold them with 200k. I'm not a die hard brand oil person because I have seen enough friends use cheaper brands and get great miles on their cars, but changing oil and filters when they or I should. Clean oil is a must. I wouldnt go recycled oil though myself.
deano55
- Posts like an L36
Re: Recommended oil
well, all this talk about green usually cost more in the end somewhere just like hybrids, cost more and take years to make any differance if at all. I would think that the used oil has been cooked and recooked over and over with engines running hot. Valvoline can make the "green" oil but I dont see new cars rolling off the assembly line with recycled oil yet so I will stick to new oil. By the way, what does it cost for a quart of "green" oil.
LeSabre in Buffalo
Re: Recommended oil
Same as a quart of regular oil, at least AFAIK. The "green" G-Oil is right in line with other synthetic oils at $5 and change a quart.deano55 wrote:well, all this talk about green usually cost more in the end somewhere just like hybrids, cost more and take years to make any differance if at all. I would think that the used oil has been cooked and recooked over and over with engines running hot. Valvoline can make the "green" oil but I dont see new cars rolling off the assembly line with recycled oil yet so I will stick to new oil. By the way, what does it cost for a quart of "green" oil.
Compared to my old LeSabre, I'm spending $25 less every fillup with my Cruze. My driving has stayed the same, but I'm spending $25 less per tank. It's not a hybrid, either. Going from about 25 mpg average to 43 mpg average will do that. It's doing better than Honda's hybrids, that's for sure!
deano55
- Posts like an L36
Re: Recommended oil
To me thats too much then, just like when they came out with 50/50 premixed antifreeze, not all that much cheaper than non mixed. Marketing is decieving these days and alot of money and time goes into it to sell the consumer on the product.
jedwards83
- Year and Trim: Currently searching for a Bonneville...
Re: Recommended oil
I don't think it's fair to say it has to meet higher standards to get on the shelf. Just because the processes are different in making it, and perhaps it is subject to a greater degree of filtering and refining, that doesn't mean the end product meets a higher standard. Synthetic oils go through more rigorous refining and other processes, but in the end you end up with synthetic oil, not a higher standard. You can argue that one product is better than another, but unless there's a specific higher standard you're referring to, it's still just conventional oil, recycled, or synthetic.LeSabre in Buffalo wrote:The re-refiner doesn't know what's in the feedstock, so they have to really filter and refine the oil to make the final product. Also, all sorts of petroleum products such as ATF and gear oil get mixed in with "used motor oil", so they need to filter out all the additives and wear metals in those to get a usable product. Then, they need to further "crack" the filtered oil to get the right grades of oil needed for engine oil. The oil made from the stuff that comes from the ground isn't filtered as thoroughly since it's more uniform to begin with.
To answer the question at hand, I think you should buy whatever modern API spec'd oil (SM/SN) is on sale, run it till the oil change reminder comes on, and repeat. I've had those used oil analyses done on the cheapest oil I could find after 7,000-9,000 mile intervals, and they suggested I run them longer. Sure those analyses are highly subjective, but that's proof enough for me. 10w-30 is good year round unless you live in colder climate, in which I'd use 5w-30 in the winter.
