OK so last Thanksgiving I had my windshield replaced, and ever since my rear view mirror has rattles and shaken. Its pretty loose. Its the auto dim and has no screw to tighten it and the small shims I was using aren't cutting it. Can someone please give me suggestions to get it tight again?
Thanks!
Rattling rear view mirror...suggestion?
RareGMFan
- SSE Member
- Year and Trim: 2000 Pontiac Grand Prix GTP
Re: Rattling rear view mirror...suggestion?
You should have taken it back to whoever did the windshield replacement. There's really no reason (unless the shop somehow used an incorrect sized mounting button on the windshield) for the tension spring-tab mounted mirrors to be loose unless something somehow got broken or bent on the tab, in which case the only remedy would be to swap the mirror out. I'd try going back to them and see what they say.
1990 Pontiac Grand Prix SE McLaren Turbo (1 of 2725 SOLD :( ), 1989 Pontiac 6000 STE AWD (1 of 1376 SOLD :( )
1990 Pontiac Grand Prix STE McLaren Turbo (1 of 1000 SOLD :( ), 2001 Pontiac Grand Prix GTP Special Edition
Ken_W
- Posts like an L27
- Year and Trim: 2000 SSEi
There's no way to stabilize it with a shim of some sort? (I must confess I've not looked at it closely)
Ken_W
Ken_W
- Bugsi
If it moves and shouldn't: Duct tape.
If it doesn't move and should: WD-40.
`05 Mercedes S500
`05 Mercedes S500
I'll take it back and see what they can do. That bastard just shakes terrible right now.
- 92BonneSE
- Year and Trim: 2008 Aura XE
Try taking it off and putting it back on to make sure its seated correctly and everything. Mine use to shake real bad when I got my subs but I took it off and put it back on and it doesn't shake at all now. I could tell I got it on a little further and tighter. Guy who did my tint must not of pushed it on all the way
2017 Cruze RS
2008 Aura - Totaled
Sold but never forgotten:
1998 Bonneville SE
1992 Bonneville SE
quick steel the entire mirror cavity, slide back in place, clean up excess. solid as a rock after sets up. i'm screwed if i ever want to take the mirror off its mount.
