Junking my bonnie
murderedout
Year and Trim: 1989 bonneville LE flat black paint 133k
Junking my bonnie
Post by murderedout »
im sick of this dang car. its an 89 with only 130k on it and i just put a fuel pump and filter on it. 300bucks and now, as before, it decides to not start. for example just 5 minutes ago i was at wally world for ten minutes came out wouldnt start. it had fuel and spark. im just gonna get rid of it i cant fix it
SSEiMan01
Re: Junking my bonnie
Post by SSEiMan01 »
Where are you located?
James May wrote:Hello.
PLAGUE PHANTOM
Year and Trim: 1968 Chevrolet Bel Air
Post by PLAGUE PHANTOM »
When was the CPS replaced last. That may be your issue
1997 Bonneville SLE...(SilverStreak)...Totaled...1/25/13...Gone but not forgotten.
1968 Chevrolet Bel Air....the project
murderedout
im in western, ky
camshaft position sensor was replaced about 6 months ago, magnet still intact.
Krenzy
Year and Trim: 1996 SSE
Post by Krenzy »
You may have gotten a bad CPS. That happens.
murderedout
i just went outside and it started up. im really leaning towards it being heat related. it sat for about 2 hours and i just went outside (around 55*) and it fired up no problem 4 times in a row. WHAT GIVES im taking it to a mechanic if i cant figure this out by thursday
PLAGUE PHANTOM
Mine was replaced 2 months ago with an ac delco unit and it is already going bad. Duralast crank sensors are junk so do not get one of those.
Post by Jrs3800 »
murderedout wrote:im in western, ky
Have you ever replaced the Crankshaft Positions Sensor ? You are perfectly describing a Crank Sensor failure....
Were the injectors firing ? You would need a noid light or a certain bulb to test this.... You can have fuel but if the injectors are not firing it'll never start..
The crank sensor is a 2 part sensor, 3x's pulse for spark and 18x's pulse for fueling... This can fail on one side or the other or simply fail completely...
murderedout
No I have not replaced the crank sensor. I didn't know I had one! Is there a write up on it or any hints or tips on how to do it? I have a FSM. Any pictures would be great!
Jfridge92
Post by Jfridge92 »
The crank sensor is located behind the harmonic balancer
Joseph
1999 Infiniti G20T - Sold
murderedout
oh im sure this weekend will be fun replacing that thing... should i put a new HB on it to while its off?
nickdalzell1
Year and Trim: '92 Bonneville SSE
Post by nickdalzell1 »
just out of curiosity is yours equipped with VATS or PASS Key? does a light show as SECURITY while starting? that can cause a no-start condition that magically seems to go away on its own, and in my case heat exasperates the condition.
1992 Pontiac Bonneville SSE (3800 Series I, 277K miles and counting! with a horrific knock sadly)
murderedout
nickdalzell1 wrote:just out of curiosity is yours equipped with VATS or PASS Key? does a light show as SECURITY while starting? that can cause a no-start condition that magically seems to go away on its own, and in my case heat exasperates the condition.
no it doesnt have that style key. But i drove it 4 hours today all highway and when i parked it at my apartment i let it idle for 2 minutes and it died. im thinking the icm is getting to hot?
1oldman
Post by 1oldman »
That's the way the ICM on the Magnavox ICM I use to have would act when it was in the process of "giving up the ghost". - BC
Ronnyboy
Post by Ronnyboy »
I remember my Uncle had this problem in his old Buick. He gave up, sold it, and bought a 5.0 Camaro instead.
If I were you, I'd give up and buy a camaro. But that's just me.
murderedout
so your saying its most likely the icm and or coils? im gonna take it to autozontastic tommorrow and have them test it a few times and hopefully it fails and we can put my car troubles to rest...except the trunk leak and the front window leak :sadeyz:
RJolly87
1994 Buick Regal Custom
Post by RJolly87 »
I give up! Many have told you the symptoms you describe perfectly fit the Crank position sensor, and I have as well in your other thread here:
viewtopic.php?f=20&t=31708&start=20
Now, in all honesty, the old magnavox ignition systems were prone to failure, and that is probably not helping, . My suggestion now is to just do both and be done with it.
Unless you still plan on junking it . . .
~Randall~
murderedout
im taking the icm to autozone today to find out if its bad. ill be sure they test it multiple times. hopefully it fails! an EPIC FAIL! so i can put this problem behind ALL OF US.
