remove front passenger seat
snira
Year and Trim: 1998 Pontiac Bonneville SSEI
Post by snira »
Hello,
I tried to remove the front passenger seat today in order to find the source for some electric shorts on the floor (probably a leak) , it all went well untill I got the torx bolt. It didn't want to get loose and I used alot of power for trying undo it, and it's torx head went bad, so I tried to drill it in the middle but I think it's hollow bolt so it didn't help. I am trying to think about a way to get it out. DId it happen to anyone to bump into this bolt and had difficulty to loosen it?
Thanks
tripscarcare95
Year and Trim: 1995 SSei
1987 GN 16K Original
Re: remove front passenger seat
Post by tripscarcare95 »
Chances are the seats never been out of your car before. Its crusted to the floor, as you do think you may have a leak issue.
I would grab a pair of vice grips and lock onto that bolt if possible. If not ground down two sides of the bolt head to give yourself some type of flat area to grip. Be sure to watch for sparks if you do the grind method.
snira
Post by snira »
Thanks, I'll give it a try.
Backhoe
Year and Trim: '98 LSS L67
Post by Backhoe »
pipe wrench
1998 Olds LSS/L67, 92K miles, Intense FWI, SSAC headers, 3.2 MPS, cat delete, 180 stat, AL 103's, HPT.
1996 Olds Eighty Eight LS/L36, 146K miles, mostly stock
1997 Olds LSS/L36, 95K miles, raided for dent free parts and sold
1989 Bonneville LE Gem (sold)
1987 Bonneville LE (retired)
snira
Post by snira »
finally succeeded with torx 50.
