OBD1 codes???
primetime2
Year and Trim: 1993 SE
OBD1 codes???
Post by primetime2 »
Here are the codes my 93 through today at Oreilly's! 12,14,21,22,23,24,31,32,51,53,54!
details? which ones do i definately need to tend to?
thanks in advance
impala67
Year and Trim: Buick pa ultra 1991, 3800series I
Re: OBD1 codes???
Post by impala67 »
these are according my 1991 a Factory shop manual:
12 -nothing, battery disconnected
14 -coolant temperature sensor, goes on if engine overheats etc.
21,22- Throttle position sensor signal low -likely broken sensor because of 22 code (same: but signal high...)
23,- intake air temperature sensor , manifold air too cold
24- vehicle spee sensor; PCM will force tranny to 3rd gear with this code!
31- PRNDL (neutral safety) switch,not so important, with this code PCM assumes D4 until corrected
32, UNKNOWN CODE???!!!
51,- Mem-cal error, faulty "MEM-CAL", if this comes after you check that all pins are connected in mem-cal socket- the PCM is broken!
53,54 -UNKNOWN CODES TO 1991 FSM
good luck! seems like you have lots to do...
sorry i´m from europe-expressions and understanding varies
Re: OBD1 codes???
Also found here:
http://www.pontiacbonnevilleclub.com/fo ... 32216c83fd
and to read them yourself:
http://www.pontiacbonnevilleclub.com/fo ... =51&t=8689
Disconnect the battery for 15 minutes. Reconnect and take it for a drive long enough to warm the engine and get the coolant up to temp. Read the codes again and see what comes back. (this proceedure clears any stored codes).
Is there any issues with driveability for example high idle, excessive fuel consumption etc?
Some things to check: under the air filter is the IAT (intake air temp sensor) , make sure it is plugged in.
Check the TPS: http://www.pontiacbonnevilleclub.com/fo ... =48&t=9098
Check the coolant sensor and make sure it is plugged in, located under the thermostat housing
Check the battery voltage with the car off and then when the engine is running, use a meter because the dash gauges are not accurate.
J Wikoff
Year and Trim: 1992 SSE
Re: OBD1 codes???
Post by J Wikoff »
I'd look into the PCM (memcal) error first. It could be causing a number of the other codes. I might also crack open the ground busses at the bottom of the a-pillars, under the carpet, taped into the wire harnesss running under each front door.
primetime2
Re: OBD1 codes???
myfirstbonnie wrote:Also found here:
at idle the car vibrates a bit i cleaned the MAF and it really made her come back to life hesitated quite a bit and the milage is at 21.5 i'm thinking these cars are better than that considering my last 93 got 28 consistently
thanks for the info i'm digging in now!
primetime2
Re: OBD1 codes???
impala67 wrote:these are according my 1991 a Factory shop manual:
23,- intake air temperature sensor , manifold air too cold it has a small exhaust leak somewhere near there so might that be that problem?
51,- Mem-cal error, faulty "MEM-CAL", if this comes after you check that all pins are connected in mem-cal socket- the PCM is broken! where exactly is this? under the dash i'm presuming?
primetime2
Re: OBD1 codes???
everything looks to be plugged in, if i need a new ecm can i buy a used one from a salvage yard? ive done a relearn on a 01 pickup but never a 3.8 ltr bonny, what does that entail?
primetime2
Re: OBD1 codes???
24- vehicle spee sensor; PCM will force tranny to 3rd gear with this code!I THINK I FIGURED THIS ONE OUT THE TORQUE CONVERTER IS PRETTY SHODDY AND THE CAR REALLY SHAKES AT 44-45 LAGGING RPM SPEED
primetime2
Re: OBD1 codes???
just went for a drive got everything all warmed up and no cel in the dash! idk but i'll keep driving it and check the codes as they come. i do notice my temp gauge will linger alittle low when its pretty cold out but normal operating temp of 195 is usually where its at. it has a new thermostat
J Wikoff
Re: OBD1 codes???
Post by J Wikoff »
There is no relearn necessary for a new PCM. Just make sure it's from a non-supercharged SE with the same final drive ratio and it will be as simple as plugging it in. It's behind/under the glove box. Accessible from below after you remove the black hush panel. It has three harnesses connected to the bottom.
primetime2
Re: OBD1 codes???
J Wikoff wrote:There is no relearn necessary for a new PCM. Just make sure it's from a non-supercharged SE with the same final drive ratio and it will be as simple as plugging it in. It's behind/under the glove box. Accessible from below after you remove the black hush panel. It has three harnesses connected to the bottom.
thanks if it comes that! ecm's are fairly cheap at salvage yards by me
J Wikoff
Re: OBD1 codes???
Post by J Wikoff »
You have to have a 93 PCM, also. You can use a 92 PCM, but will have to swap the memcal chip out of yours, and won't be able to rule it out in that case.
DASHAWN1234
Year and Trim: 2005 PONTIAC BONNEVILLE SLE
Re: OBD1 codes???
Post by DASHAWN1234 »
does anyone know what the p0455 code is on a 2005 sle bonneville?
primetime2
Re: OBD1 codes???
DASHAWN1234 wrote:does anyone know what the p0455 code is on a 2005 sle bonneville?
google.com
obdII codes
J Wikoff
Re: OBD1 codes???
Post by J Wikoff »
They are in our Techinfo up top.
primetime2
Re: OBD1 codes???
try this link
http://www.obd-codes.com/p0455
not to sound like an ass but isn't this in the wrong section of the forum????
DASHAWN1234
Re: OBD1 codes???
thanks guys and im sorry this is the wrong forum
primetime2
Re: OBD1 codes???
got the exhaust fixed the donut was gone by the manifold. it was determined by my brother that the car was missing on one cylinder! so we pulled plug wires till the tone stayed the same. since the plugs and wires are new we determined it had to be an injector so we replaced the #1 injector, front of car far left cylinder, but the car still seems to have a miss! what should i try next or do?
thanks for all the suggestions again
primetime2
Re: OBD1 codes???
so i put a new thermostat in 2 months ago and now it won't heat up to 195! sits right around 170-180 maybe even alittle lower! is that the only thing that controls my temp? I know they are cheap so i'm planning to go get another one.
Re: OBD1 codes???
As for the miss, have you checked the coils?
What are you reading the temps on? The dash gauge is not accurate at all.
